rip 88e
Dw the meeting in London on Friday night went well, hence the price drop today.
88E is all about unconventional oil, hence the large number of unconventional investors.
Or maybe the board just talk heaps of shit and only the vocal ones believe them lol
30 billion wiped off the asx...don't think it's the work of Dave Wall and co...
4 hours ago, Kinkstaah said:
The person you bought the engine from should know, I never got asked for the Rego for the engine that I provided, ever. They just ran the number to make sure the engine wasn't flagged as stolen.
Have changed engine numbers at Vicroads like 4-5 times now. Never once got asked for the rego of the car the engine came from.
Also no reason to remove Nistune ever, so the best way to remove it is not remove it.
It says something about your luck with automobiles when you retain this level of familiarity and confidence with the engine swap process at your road traffic authority
  • Like 2
18 minutes ago, dezz said:
You could buy the rarest gtr in the world and you'd still be beneath me you peasant. Which means you're even further beneath Ric
lmfaooooo
i missed you man
39 minutes ago, Daz said:
could be a good entry into 88e soon
Market in a downturn, the stock troughing off the back of a profit take from positive announcement...Warren would say now. A mate and I think it's got the 3s left in it until the next news but I'm getting itchy on the sidelines. Confident that even at this price the next batch of news or spud of icewine 2 well could easily send it back up to 5 cents plus. One thing is for sure and that's that there is money to be made short term on this gem.
Looks like majority of shares traded between 3-4c so should see some support around there.
Agreed money to be made, I'm watching.
Shit day overall on the ASX. All my shares held ground though :)
Are you mostly in specs?
One thing I love about them is their resilience in general to extraneous market variables
No f**ks given for most ASX200 falls
Hot Copper is pretty funny sometimes.
First they were blaming the down-talkers. Then they blame the poms. Then they blame the day-traders. Then they blame peoples lack of faith. Now they blame the chinese.
  • Like 1
Yep mainly specs
Have one I'm expecting big things from tomorrow :)
Knowing the sharemarket it will probably go backwards on good news lol
  • Like 1
<-- gambling n00b. used my creditcard on sportsbet a few weeks ago, had no idea about cash in advance charges. that shits bullshit. i withdrew my winnings as soon as it was available. my statement says I got charged $1.75 for interest that month. bitch dont waste my time.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
