1 hour ago, UNR33L said:
14656399_385889771798994_797822290495140
if you are  going to drive a falcon or commodore without flared guards, you have to accept you will have shitty offset on the front or ridiculous camber
No matter how hard you try, there is no option
could be worst, could be a 'stanced bro golf' :P
But yer this guy told me his rims fit, i told him no.. they dont.. he had to customize control arms and everything and they still dont fit. i think they're 10.5s or some shit on the front
Was doing some annual compliance stuff at work and in the program there is a car that for some reason represents a test on commercial property valuations... Anyway it's a fiat 500.
Was stock last year, but this year some IT nerd has stopped some TE37SL's on it.
I thought he was driving the topstage S14?
Is he driving the Team Lori Bluebird aswell?
Yep, he's a busy man.
But no offence, the bluebird is a half job because it never does more than 2 consecutive laps.
Boys and girls this is why you don't drop in a second-hand motor and hope for the best.
Number 1 conrod bearing spun and caused damage to crank. Oil pump drive also damaged.
Seller has agreed for a partial refund & the build will continue!
On 6/24/2016 at 8:03 PM, emts said:
Carpel tunnel, had surgery, tried to get back into it, on going issues could not keep going.
he was shattered.
he still turns up to some gymkanas and such
Has anyone got any recommendations now Mick has hung up the spray gun?. I want to do a windows out full car respray with my 32.
Andrew
2 minutes ago, joeyjoejoejuniorshabadoo said:
Why bother. Just spend the same amount as a new paint job on a final inspection detail every year
That's the VWL way
Needs some TLC after 10 years of track work.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
