I usually try to holiday somewhere bogan aussie aren't
I also have zero interest in going to Thailand
But I mean cos the king just died after 70 years on the throne so they have basically outlawed fun for the foreseeable future
  • Like 1
Sharky said it's all sweet m8. You don't really think they're gonna put a stop on their biggest industries (sex workers and selling beer to bogans) for a year do you?
I'm not really interested in finding out lol
I went to Belarus before I ever went to Bali though so I guess I'm in the minority
  • Like 1
Third world country
Third world cost
Third world hygiene and healthcare
Third world experience
Can be good and bad but you don't always get to choose which parts you get
24 minutes ago, dezz said:
I can vouch for Thailand's hospitals being as good if not better than ours.  We're just so far up ourselves that we think that if someone can't speak English they can't possibly be any good at anything...
You can vouch for the food that poisoned you there too
A lack of English isn't at all my reason for saying that - besides my comment being about Indonesia/Bali - a lack of legal liability is
All those Indos heading home with a case of Aussie belly
I ate street food in Vietnam and Bali too, when in Rome, but no denying the risks are greater in places that don't have health inspectors checking their shit or the potential to get shut down. The holidays are cheap; there has to be a trade off somewhere.
chicken kebab off a bike vendor in Viet.
as in the rotation of the chick skewer was linked to the bike pedals.
that was my balliest move.
on another trip ate same as co worker on everything but last night, he got salad with meal I had chips.
he ended up in hospital on a drip, I ended up at a bar with a bunch of locals.
when you can see black flecks in the water, stick with beer and deep fried shit.
got to Malaysia yesterday and first thoughts is it's up with Hong Kong as fav asian place, really liking it.
Just now, Birds said:
Bali over Vietnam
Really
I guess they don't have Bintang singlets in Vietnam
People were nicer, don't get me wrong the hotel staff etc were fine, it's the random taxi driver / people on the street that shitted me in Vietnam
I mean Kuta wasn't that good in Bali but other places were decent I thought, maybe it's because everyone told me Vietnam is so good and I had high expectations
  • Like 1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
