My mates use the roulette table to pregame in vegas.
one drops 5$ on red every spin the other black, split the difference at end of night and as much free booze as they can drink
5$ each every 37 spins on average aint bad for booze.
  • Like 1
thats the most australian thing ive ever read lol.
also, f**k were lucky to be strayans,
USA is a proper shithole
  • Like 1
had no money on alvarez. just for anybody KO. If McGregor went on to fight Khabib (doubt it), i would seriously want Khabib to win. He probably couldnt take a left to the face, but if he's smart and doesnt play the boxing game, McG would be in a very tough spot on the ground. The Russian is crazy strong on the ground. Would be a great fight.
Also had money on Kovalev over the weekend. dominated the first rounds, then dropped off a bit, but Ward dominated the scoring. f**kin rigged bro.
If I ever wrote off mine and had the option to buy it back half cheap I probably would to part out / sell as is at a profit
Pretty expensive engines
Edited by UNR33L
I'll be the first to admit:
There is profit to be made betting against every match I place a bet on.
I put a lot of research into most of the UFC 205 fights. Barely broke even. Some surprises for sure. But that seems to be the way with any unorthodox money making... It's all timing and luck.
Thomas Jefferson said the harder he worked the luckier he got. But trust an American president to say that shit.
When I used to use sportsbet, years ago and muck around with about $100 a year, there was a point where I was betting on surfing...actually trusting waves to deliver me wins. At that point I stopped...
  • Like 1
You only made .1 cents?
Currently on-site waiting for server data to copy from old-new hardware zzzzz waiting for that loading bar. #itlyfe
Will still be an hour or so I reckon :(
Edited by UNR33L
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
