9 hours ago, UNR33L said:
Exactly what I'm afraid of in a few years, government seeing everything nek minit in court for all the piracy n shit.
When I worked at a small ISP we'd get warnings all the time from all the big movie makers and have to give the customer a warning, I've been downloading movies with Telstra for 15 years never once received a letter.. clearly they just don't give a f**k. I dunno about the government though?
Had NBN for over 2yrs. never received a letter.
1 hour ago, Leroy Peterson said:
Only works for sub-$100 transactions. I thought y'all were VWLBC?
Plus I try to avoid the few days it takes to process those transactions if possible.
You can use above $100 just have to enter pin like you would inserting it
Process delay is annoying but I think if you've entered pin it should go through straight away like inserting
Works over $100 just need to enter your pin after tapping
I've got a ME bank debit card I use once a week with a tap, and if I use it every week once I get a free village movie voucher at the end of the month it's pretty rad considering movies cost a fortune these days to go and see :)
Edited by UNR33L
I did not know this. Interesting.
Apparently america is transitioning to PINs only and everyone is chucking the shits. VISA insisting on signing because they dont think people will be capable of remembering their 4-digit code. lol. And walmart is suing them for it. lolz.
I just use the same pin for all my cards, probably not best practice but at least I can remember it.
88e on it's way up, I predict 50 cents by end of today
Edited by UNR33L
If you put that on HC you would have won post if the day and become a valuable member with 1 post then everyone would follow your shares portfolio for inspiration.
  • Like 1
1 hour ago, Spressy said:
not trying to be a nuisance, but what's the reasoning with cash only?
In the case of Mohsen it's to eliminate any paper trails thereby voiding his avenues of recourse when he inevitably pays for defective defective goods and services
4 hours ago, joeyjoejoejuniorshabadoo said:
Apple pay allows over $100 as it's thumb print ID'd
Hippy
If some guy was paying for his petrol and fumbling his phone around trying to unlock his phone and find the app I'd be forced to jump kick him out of my way
But srs, yeah in 5 years we wont even have a wallet
Edited by UNR33L
Double-click the home button from standby mode, it opens and confirms fingerprint instantly. It's quicker than a physical card.
I'm paid and out of the store while you're still standing there touching yourself over some lame android feature you will never need.
Fk if I could be bothered digging up posts of you slamming Apple and fanboiing android phones
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
