going out for bevs with the vegas crew tonight. ITS GON BE LIT
also was on groomsman duties last week.
f**k me its hard work, best part was the reception.
as we say in arabic "ana kenit metfi" "i was out like a light" lmao
Got some good Vegas stories? or are they so bad you cant say? lel
That place is so loose, some of the shit I did there was sooo stupid a few years back
On another note, got my 10 year RACV Silver card today (10% off) in the mail.. man I'm getting old
Edited by UNR33L
Just bought a 30 pack of VBs and cracked one open, fark going down well m8 haven't had beers in ages.
Where from? I tried to buy a 30 pack from dans online and got told they stopped selling them in Vic.
  • Like 1
Nikka from the barrell?
So a quick google confirms they have been offered a base wage of $19.50/h (50c above award) with all overtime and penalties still on the table.
considering they are calling this a 65% pay cut that means they had to have previously been on $55 per hour base + all penalties/overtime.
Cry me a f**king river and bring me a delicious VB
  • Like 1
On 12/3/2016 at 8:06 AM, Count Grantleyish said:
^ What Ham said.
Just the asian old dude at bottle joint down the road from me near Westall station
I'm actually surprised there's no hate towards VB in here, "Ohhh m8 you drink VB you bogan, no taste buds etc"
Edited by UNR33L
Yeh it really isn't that bad, most of my mates that hate on it aren't even beer drinkers, typical.
My current favorite 'nicer?' beer with a dinner or something is a 150 lash's pale ale though
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
