1 hour ago, Leroy Peterson said:
Or you could be lame and just accumulate and then leave a sell order for like 3 months at a ludacris value just waiting for it... Im sure there are lots of people who do that
Nothing wrong with this strat; it's medium to long term holding and pretty much what I did to make the first significant chunk of profit from ol 88e. Though with significant enough jumps, you tend to care not for queuing up an order well in advance for the sake of an extra couple hundred dollars when you can just sell to the current buy queue.
Queuing up a sell order is IMO a better strat for short termers and day traders as that one pip of 0.1 cents is more often than not your entire/only profit. With 270,000 shares that's $270 minus $40 brokerage = $230 profit, from investing $10k @ 3.6 cents.
You should follow me on a short term trade sometime Leroy...be interesting if you run into my luck or dezztroy it.
This is how a motorbike should sound:
like a small 4 cyl sports car.
Also think ive narrowed down the pulsar issue... i think the now-independant crank trigger and cam trigger are out of sync. now sure how or why. CAS disc is firmly in place, may need to get tuner to check that they're lined up correctly. After sitting untouched for 2 weeks, it started first time... but yet after that it just cranks forever. I'm just shitty i gotta organise and pay for a tow truck when it really should never have left the workshop...
1 hour ago, Daz said:
You got at least another 3 month wait lol
Probably
Head is back though, which he's porting and polishing now
So machinist isn't an excuse anymore haha
Should see the fuel system he's putting in the 34R :O
9 hours ago, Birds said:
Probably
So that was just the first excuse lol
hoping to see his GTR on the hwy by 2020
47 minutes ago, Leroy Peterson said:
Pffft polishing isn't worth the time or money. Sounds like an excuse to keep your motor disassembled for another month
Is the car going to be tuned on Barry's dyno?
Using work on it as an excuse not to do work on it?
Barry doesn't have a dyno, but it'll be tuned by his usual tuner, cause I like the tuner round there
24 minutes ago, Leroy Peterson said:
Barrys workshop has a dyno doesnt it? Cihan still tuning or is he still part time?
Nah
Shop next door to his does, but he doesn't use them
Yeah Cihan is still tuning to my knowledge
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
