1 hour ago, Leroy Peterson said:
Or you could be lame and just accumulate and then leave a sell order for like 3 months at a ludacris value just waiting for it... Im sure there are lots of people who do that
Nothing wrong with this strat; it's medium to long term holding and pretty much what I did to make the first significant chunk of profit from ol 88e. Though with significant enough jumps, you tend to care not for queuing up an order well in advance for the sake of an extra couple hundred dollars when you can just sell to the current buy queue.
Queuing up a sell order is IMO a better strat for short termers and day traders as that one pip of 0.1 cents is more often than not your entire/only profit. With 270,000 shares that's $270 minus $40 brokerage = $230 profit, from investing $10k @ 3.6 cents.
You should follow me on a short term trade sometime Leroy...be interesting if you run into my luck or dezztroy it.
This is how a motorbike should sound:
like a small 4 cyl sports car.
Also think ive narrowed down the pulsar issue... i think the now-independant crank trigger and cam trigger are out of sync. now sure how or why. CAS disc is firmly in place, may need to get tuner to check that they're lined up correctly. After sitting untouched for 2 weeks, it started first time... but yet after that it just cranks forever. I'm just shitty i gotta organise and pay for a tow truck when it really should never have left the workshop...
1 hour ago, Daz said:
You got at least another 3 month wait lol
Probably
Head is back though, which he's porting and polishing now
So machinist isn't an excuse anymore haha
Should see the fuel system he's putting in the 34R :O
9 hours ago, Birds said:
Probably
So that was just the first excuse lol
hoping to see his GTR on the hwy by 2020
47 minutes ago, Leroy Peterson said:
Pffft polishing isn't worth the time or money. Sounds like an excuse to keep your motor disassembled for another month
Is the car going to be tuned on Barry's dyno?
Using work on it as an excuse not to do work on it?
Barry doesn't have a dyno, but it'll be tuned by his usual tuner, cause I like the tuner round there
24 minutes ago, Leroy Peterson said:
Barrys workshop has a dyno doesnt it? Cihan still tuning or is he still part time?
Nah
Shop next door to his does, but he doesn't use them
Yeah Cihan is still tuning to my knowledge
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
