1 hour ago, Birds said:
Rather lose a few grand than miss out on a hundred grand
Birds waiting for 88E to hit $1 a share be like
But srs, ill be patient. Even though I got given a scratchie today, and I didnt even win $1 so whats the point in shares m8, odds always against ya.
Should've sold out at 6.6 and bought back in, more shares for less than I've got invested now... Easy in hindsight. Bought in on another share last week, put a stop to the surge it was on almost instantly... I've got this shit down to a fine art now
Buy when people are selling
Sell when people are buying
Some of the oldest and simplest trading advice but rarely do people follow it
1 hour ago, Down_Shift said:
Anyone went to that fully sik meet in docklands? Was it like how the media made it out to be?
i got invited but didnt go. If I had of known it was a Northside meet I wouldnt have even considered going.
Mighty Car Mods made a 9sec Barra car, wheres your 9sec pass Leigh? you got 2 more cylinders and bigger guards.
Or are you all about those 2 wheel cars now? gonna sell the ford and move to a smaller, lighter and less fuel efficient subaru?
Pretty good episode wasn't it, as if they didn't do a barra like this earlier.. bit disappointed it was only one episode though :(
Shows what the barra is capable of once you blow more air into it, the internet comments exploded with discussion of the 2jz being a better/worst engine still.
Lol barely been riding 2 wheels lately due to shitty weather, that's the only problem with bikes.. track day in the wet means you need wet set of tyres or risk snapping your shit up.
Ford is for sale, one of those 'will sell for the right price but may be selling for 6 months' sales. Generally FPVs holding decent value these days though anyway. And yes, might buy a decade old, shitty engined Subaru, unless you have better ideas for around the 40-45k mark :P
Edited by UNR33L
I'm all about the newer Lexus' these days. Can get a decent one for much less than 45k... actually scratch that, theres not much other than the IS350's, which are really holding their value.
RC350 might be cheap enough by the time you sell up. Wont be as powerful but much nicer everywhere else https://www.carsales.com.au/private/details/Lexus-RC-2015/SSE-AD-4573607/?Cr=11
Didn't you just setup the Falcon for track? brakes and cooling??
Find something cool to import. Maybe you'll be in the market for an E52 soon if your missus decides to "seal the deal" lol. YOu never know what might be eligible for import in 2018.
I actually really liked these in Japan. its like the kei version of an 86 for tuning. though, only in japan limits who makes stuff for them. Can get them landed for mid-20's basically brand new.
That Honda thing doesn't look practical at all, still need to tow bikes and store a heap of bike gear + generator don't forget :P
The Lexus looks nice but 18k over budget, also missing a turbo so I can go stututu
Did the brakes but not cooling, stock brakes were in need of a machine/wobbly so just upgraded
Edited by UNR33L
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
