9 minutes ago, Leroy Peterson said:
Birds chasing dat hot copper efame. Don't lower yourself to their level
I'm a washed up celebrity on there
I created their level
Some seriously interesting stuff on there though. It used to be nothing but speculation and cheering each other on for support during the downturn, with a rare informative post here and there. Now there are some experts on rock mechanics and oil drilling offering up explanations of events. Will be staying tuned.
Yeah I read Ya's posts and basically ignore the rest.
No one gives a f**k about some dudes 92 yro dad passing away and a f**king essay about how he's dealing with it. Then 400posts of people sending their condolences. It's an ASX forum, not a Remember The Titans discussion board.
Now I feel like registering just to do that
1 hour ago, UNR33L said:
Birds told me it was the worst time to sell when I did :P
Now I can buy back in 2c cheaper :D
Yep, got the call wrong on that, but had 88E not released an announcement that confused the market then prices would still be the same or possibly higher.
Regardless I think it's dangerous not to be in the share at the moment. Whatever you pay for them now will seem insignificant if the flow is proven good.
In piece of shit laptop news, msi rekin it's some shit about this chipset not being compatible with Windows 10, something about Intel not supporting some rapid storage shit... Gave me the recovery process which doesn't work, but apparently I'm following the two steps of power on and press f3 wrong...
Won't boot from the windows 10 usb I made when I updated after getting it back either.. Only idea I can think of is make a windows 8 boot disk and try boot from that and install... Then be stuck with windows 8... Or buy a new laptop..
47 minutes ago, Leroy Peterson said:
Why that?
Every time there's a massive global ransomware attack or another variant of it
Too expensive to get them though :D
Edited by UNR33L
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
