4 hours ago, Leroy Peterson said:
All 6 cylinders sound shit.
You know what actually sounds amazing with straight pipes? A 3 cylinder lol
well a 6 cylinder is obviously twice as good
  • Like 3
I disagree...though most of them have better inductions than exhaust notes
RB25 mild steel without a cat converter
E46 M3...dat rasp
These two changed my mind about 6cyl exhaust notes
  • Like 2
6 hours ago, TiTAN said:
Eagle speedster?
Didn't sound amazing on my phone, would have to judge in real life...not that that's gonna happen anytime soon. Was like any 6 cyl straight out exhaust to me and like it's constantly on song. I prefer exhaust notes that change through the range, like my GTS-T, which idles softly and is "sporty" but really screams up top.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
