1 hour ago, UNR33L said:
Birds when am I rebuilding your PC for special favours?
Surely due for an upgrade? :P
As long as it runs CS:GO I see no need for an upgrade
No time/interest in any other games at the moment
4 hours ago, TiTAN said:
You can run csgo on a potato so you will be fine.
Mine is a shoebox mini itx
Bout 5 years old but still doing everything I need with ease
I had an itx z97 machine. It's now my work pc complete with its 780 ti that spends all its time clocked up and pumping out heat as its an nvidia bug when driving 4 screens that they can't go down to idle, the home machine to replace it was an matx z170 machine and a 1070 as the other one gave me the shits with random bios resets when you turned it on, totally worth the $2500 it cost to buy the new one.
Weird. Computers and components are so cheap these days. Everything seemed so much more expensive when I was a teenager saving for a build.
My shoebox is a tight fit but small desk footprint and about as small a case as you can get with full sized components / decent power supply. Very portable for LANs not that people really do those anymore. Surprisingly doesn't get that hot, except in summer, where the side of the case will burn your hand...and I run a USB fan pointed into the vent nearest the CPU.
Yeah it's a bit like that these days, the hardware is starting to overpower the software / games.
I think optimisation is getting better, because you can really tell an early access games that melt PCs and has prehistoric ragdoll physics.
Also I think graphics manufacturers are focusing on crypto mining hardware rather than backing developers to. Push better products etc
I can't keep up with GPU releases these days
Maybe my time awareness isn't on track, but in the teenage years it was a big deal when Nvidia released any new model like the GeForce 2 GTS. Now the number on the end just seems to go up every other month.
lol reminds me, some guy at work fooled the IT department into building him a rig with a Quadro card saying he needed it for CAD...he had it mining bitcoins 24/7. He is...no longer with us.
It's still a big deal, hell since you got your card 5 years ago there's only been 2 releases (Your 770 > 9xx series > 10xx series) yes they missed the 800 series.
I only just went from old trusty 780ti > 1070GTX last year & still run a 5 year old intel cpu, the only reason to get a newer card these days is if you're running a 4k or 1440p monitor, if you're running a 1080p a potato will suffice.
/nerdlinesaustralia
/nerdlinesaustralia
Those are series though...within them they seem to continuously release an array of cards like 1050 1060 1070 1080 1080ti Titan XP etc.
True there's a lot in the series but that's just like a car having options that are better but cost more. WRX, WRX Premium, WRX Spec R, WRX STI, WRX STI Premium, WRX STI Spec R etc.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
