1 hour ago, UNR33L said:
Daniels donuts way better than KK
Used to live so close to Daniels when I was in Clayton, probably one of the big things I miss about the area. RIP
That laptop isn't bad for the price, rip out the shit 1TB hard drive and put a SSD replacement in as well.
So 4 months and they still haven't sold the place we are renting, hopefully they say f**k it and keep it for a bit longer. Asking way too much 890k for a 3 bed townhouse, yes its new but everything cheaply done and nothing special.
You'd be nuts to buy that when you can still get a ~600sqm block in parts of Vermont with an old dumpish house on it for around the same, subdivision STCA.
Both donuts are pretty Shitful, especially Daniels.
Like for real, its the same Donut with slightly different toppings.
Also unfortunately contract cancer every time I go near there due to the complete abominations in the parking lot, and their equally cancer-causing owners.
f***
  • Like 2
1 hour ago, Leroy Peterson said:
What are you trying to say about Bunnings Snags?
Nothing fancy about handing over $2.50 for a sausage in bread
I do remember when they were $1 though
  • Like 1
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
