The teclast is similar to that acer. But comes with win 10 pro instead of home, has more ram, 128gb ssd and an all aluminium body.
We have gotten about 6 of them to give out to people at work so far as they are cheap enough that if someone destroys one it's not a big deal while still good enough to get the job done without looking like they are a really cheap laptop.
I thought it had 64gb emmc from my google? At what price point (for everyday consumers) was the 128gb ssd?
The Acer is aluminum too
Edit: found the 128gb for $450 on eBay delivered.
There seems to be trade offs in each case - 10 hours battery versus Acer 15 etc. Buy online versus Aus retailer. With these notebooks the finer details/specs come down to preference or which compromise means the least to you. What shit me when looking is that all the retailers had their ever so slightly different takes on a given model so that they can't be price matched on them.
Yea, I think we are paying about $460 delivered from gearbest. Win10 pro vs home is a deal breaker for business use though and is generally $100 more to get pro.
Follow the announcements not the people shook by em; key words "as expected" repeated about 5 times throughout
My only regret is that I topped up lastweek instead of today
London seems to be reading the announcement a bit more carefully
I did follow the announcement, they are in the middle of the artificial lift and haven't gotten enough frac fluid out for any meaningful data as has been mentioned for over a year. So after it crashed, I bought some more.
19 hours ago, Birds said:
London 3.3 equivalent
Watch us follow them back up tomorrow
Cause we can never lead them anywhere except down
Aussie investors are the worst
Called it; close on 3.3
This is why you don't follow the market...they are just following other people and doing it emotionally. So the quick sell off snowballs into a Chinese whisper of the sky is falling. That's why you buy when people are selling and vice versa.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
