5 minutes ago, TiTAN said:
Even mid 11 isn't usable on the street for a rwd car, as soon as you give it anything in 3rd or below you are doing power skids.
Pretty much, although I found traction a lot worst with similar power in a skyline than my falcon (probably the less weight and stiffer chassis)
250awkw with a cooler zort and tune wow. How does the DSG hold up
Should have bought the wife a Golf R not an Evo X
Not sure about the dsg, the dry clutch 7 speed boxes aren't known for their reliability but the 6 speed wet clutches seem to go ok, but I'm not sure how they go at that power level.
20 minutes ago, UNR33L said:
yeah I have, big fat NT05s with massive sidewall lol
still liked to get squirly
Gooby pls
NT05 is not a real decent tyre
It's a budget summer/dry tyre and they are okay for the price
If you want traction put something softer on like proper semis or MT streets
You never know, resale might be better with the Mitsu in a few years...
Probably will be. Can't exactly buy a new one and there's no current known plans to release a new one.
It was a solid option for an affordable ready to go track toy.
Pajero? Only came in petrol and aren't produced anymore... And you call yourself a country boy.
Nope came in diesel too and still available new. It's just the same car since 2006... And rumoured be replaced by a rebadged Nissan offshoot.
I did update that very quickly, like b4 your response.
mixed up the UTE and SUV.
done 100's of ks in a navara and it's a nice place to be (for a ute)
drove Hilux's for years and they were so cramped and uncomfortable would never do it again.
If I had the money / space I would buy a Ranger, would be great for going out bush and throwing bike on the back.
Current car tows fine but gets a bit slow and harsh when going on some of those dirt roads to the tracks.. #firstworldproblem
I got no problems with hiluxs. just needs 5 or 6 gears and wider tyres than 205.
I've seen enough Ford Ranger engines explode to put me off them... dont know how the new platforms differ from the old, but considering how well theyre selling, might it aint so bad. I'd still take a new hilux over it though. Lexus and hilux are probably the only toyota products I'd ever own... except maybe a Century.
New Rangers are quite different from the old that shared their platform with the Courier and Bravo. Those vehicles had terrible gearboxes too, so many breakages.
Even a slightly capable off roader - we have a fleet of them at work that we take four wheel driving occasionally.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
