Easiest way is to tap a thread behind the actuator on the transfer case and use a bolt to pre load it.
Expensive way is the t case mod by changing the plates.
i love how this post give all the right answers and was completely ignored
Yes i agree that the post has some good and bad idea. But its intresting to see the ideas that we all have. Some are not practical at all but opens the door to understanding peoples point of views. Even though some makes no sense. Kind of like on any topic. Some will always sound crazy.
But here what happened to me.so far i changed the whole attessa pump. And man. I cant see a difference now between reaction time from my r33 gtr to this gts4. All i have now is traction. And yes all i do is drag race, i know lost of the guys here circuit race but some if not lost of things are common. I cant believe the difference this attessa pump made. When i was bleeding it up i noticed the difference right away. The manner in which the pump sounds and the pressure on the line. Now when i drive if i go on the gas a bit and bring in just a little bit of boost the front torque split gauge starts to move up to about 15% and now my 4wd light stays off on start up every time. Before it would come on. Then id have to stop cut the car off and restart it.
From the r33 to r32 i can without a doubt mension tye difference. First the r33 gtr is more relaxed for exsample. R32 whiles driving tends to always apply the front wheels on the r33 gtr this doesn't happen unless there is a slip condition.
Im still going to rebuild my transfercase and when these driven and drive plates come from greenline. (Much thanks there guys) next im working on have the manual engagement system worked out, but im going to install it in my r32 gtr. (Bare wit me it get confusing because i have a few cars i mess with.)
This gts4 chassis i experiment wit.
Thanks for all the ideas guys. Keep them coming. And if anyone has info where i can get a good manual system from please PM me. Thanks.
Edited by MJTru
Talk to Robbie at RIPS, they run some sort of manualised system in their drag cars.
You can sort of see it in this vid-
That's Glenn Suckling's R32 which he bought and put one of his 3.2 Nitto engines in.
Lol. No i dont think ill be doing that bolt mod. But i have ordered a set of friction plates and drive disks from greenline.
I hope these guys are for real and i dont have to visit them. After i paid no one is answering my emails. I wouldn't do business with them again.
If the disk do arrive i will rebuild the T-CASE. And try the manual system here is my first part that arrived. Attached photo.
I will get this to work. Im looking for the hydraulic pressure used for full lock on the T case. ???
I was trying to find the pressure from a video by looking at the gauge, but the image isn't clear enough.
Robbie from RIPS has bought the car and is now dragging it. You could try an email - you might get a reply or not?!
http://www.ripsracing.com/
I looked into it, apparently 220psi stock. I was looking to bump that pressure up a bit in the Stagea.
I have done this mod to several track cars I used to work on and feedback was that it worked extremely well.
Something to be aware of though is that for a street car this wouldn't work all that well as it does leave the transfer case prelaoded at all times. You need to get under the car and adjust it as well, though adjustment is very easy given its just a bolt and locking nut.
  • 4 weeks later...
I have finally gotten a set of these disk from rhdjapan. FYI i spoke to mr. Hobbs and had him place the items on there site. (Search by part number) I was really suprised at how fast he got them to me.
This week i will be pulling the box out and ripping it apart (T-case) to replace these friction disks. I cant wait. Then ill focus on doing the manual pump system. I just wish there was a kit out there to buy from a store. If it gets to complicated for me ill just go get the torque split controller.
  • Like 1
Hmm. It was very easy to do. I just didnt change all the seals that most recommend. No leaks so far. I see what most said. Dont add the disk and block the oil drain holes in the friction disks drum.
My mistake was that i didnt soke the disk in oil before installing them. Notice it locked up in 4wd wit no oil. So we didnt want to take it all apart and came up with the idea to take the engagement piston out, then it started to free spin. So we added oil and spin it free hand as well as drowning it in oil making sure we wasted money buying oil and having the whole friction disk area soke in oil. (Dumb). we then measure the clearance and we were at the minimum of .008. Once soked wit oil we still couldn't free spin it by hand. But sure with front wheel resistance it will free spin.???
Here is some photo's
Very simple to do so far.
Edited by MJTru
The old disk were good but just a bit worn. I measured it before disassembling it and it was over .020 inch. Sorry for that. So definitely at .008 its within factory standard.
Damn no one is intrested in this post it seems like. :(
Well i just bought the ETS PRO from fullrace. Cost 660 usd dilivered.
I found some info saying the samething someone said here. I can put it in manual mode and full 4wd lock and let it rip. Then at high speed go 2wd.
Im just trying to think of a way i can get it to go into 2wd automatically???
Brain buster.
Any ideas. ???
Just off the top of my head, you would probably need to run a circuit from your wheel speed sensor circuit to your pump/ controller. Or some setup from the G sensor signal or both. But aren't you using a manual override anyway?
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
