Have a look at what I wrote.
I wasn't going to sit there all night finding the cheapest price around. It all comes down to what product you use. Some may want Argo rods, another guy might use HKS. I'm not going to sit there and price up 20 different combo's.
What I was trying to say was at the end of the day it's not $7000 worth of difference, even if it was, I still wouldn't use a stock throw crank.
For what it's worth, a 2.8 is still too small.
Ahh ok fair enough,
you just decided to throw in the cheapest stroker kit you could see and inflate the prices of rebuilding a standard. To throw the results. Point made.
Lol at 2.8 even being to small.
Apparently street use means nothing. ONLY TRACK!
Lets get onto the non mentioned side of things... Wear and tear...
technically the Stroker kits won't last as long as a standard 2.6......plus the additional wear on other components.
in saying that #gtrlife they will destroy themselves anyway.
  • Like 1
By the time you get that little bit more wear on the thrust side of a bore from extra stroke it would have either already blown up or require something else done anyway.
The argument of stroker wear is invalid in my opinion
  • Like 1
Anfanee. What's wrong with the Tomei kit? It's been in my car for a decade. Price up a nitto, BC, HKS. Choose whatever!
You could go and get the Tomei 2.6 full counter crank for $9k a unit?
Ahh ok fair enough,
Just saw a full 26 bottom end on eBay for $400 and a long nose crank for $90 wonder what capacity Freddy used, he did alright didn't he?
I didn't say anything was wrong with the kit at all dude. I'm sure the kit is fantastic, i'm a huge fan of tomei stuff.
Nah for that price i'd get the nitto crank for $4600 a unit lololololol
I was just commenting that there is a little more than a 1k difference, and just trying to show the other side of the story.
But i do know where you are coming from, if you include a crank, there is not a huge difference overall.
looking at my receipts from my rebuild....The difference was pretty decent. Though i didn't need a crank.
Also in saying that Nengun have the HKS step zero for under 4k... holy shit! My difference is still over 2k.
But for that price, get the HKS step zero. 100%
@ Hadouken:
Why not? Oh yeah because its a 26 rather than a thrashed out rb30 that needs a rebuild.. :huh:
Nah I'm still standard 26 here and have no bias.
It's just a $400 block with probably a crack in it and a $90 crank that needs machining anyway if it is in good nick.
Yeah I know mate. I am just saying in general the contradictions that exist. Someone buys a thrashed out 30 and builds a forged 26/30 and they are legends, but someone else does the same on 26 and they are tight arses..... Makes me laugh.
engine parts are only ever as good as the workshop that screws it together.
I've seen first hand massive dollar equipment hand grenade on first run/dyno pull and on the other hand I have witnessed bone stock unopened motor's that had "claimed" to be built go on to produce over 400wkws for years.
"I BELIEVE THE MAGIC IS IN THE ASSEMBLY "
Proably shouldnt tell you i plan on building this myself then
I don't doubt the displacement argument but my engine is 2629cc at 87x73.7mm.. If I was going all out with a new N1 bock and stroker is 2738cc at 86
5x77.7mm thats 109cc difference for 7+ grand extra, you'd be nuts to take a virgin block straight to 87mm (assuming for a 2.6 refesh my crank and rods are fine, just new pistons) I would have though improving your VE% by 3 or 4 percent on the 87mm 2.6 with good head work would yeild similar results? If you're going all out, sure do both. But on an assembled 2.6 engine you'd see similar gains with just doing the head work. If I wanted solid grunt I'd be looking at over 3L for sure.
Edited by burn4005
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
