unfortunately stroking it won't do it. To do it properly you need to do quite a bit of head work.
The same could be said for staying standard capacity too. To get the best result of any size engine requires a combination of parts that will work for the desired outcome. That means $$ unfortunately. At the end of the day, the bottom end is just an air pump.
Well so far ive only learned we need more stroking, Head, and now fisting...sorry multiple fisting.
Surprised no one has discussed better oiling.....because all that works gonna hurt real bad. :)
  • Like 2
