Hi all...want to see if someone can help out with this...I bought this low 70k 34 a year ago..ever since its had boost issues... so today I wrote down the max boost I recieve with my boost controller turned off and using my internal wastegate..
1st gear I get 7psi !
2nd gear 8psi
3rd gear around 9psi
4th gear just under 10psi
5th full boost of 10 psi.
I use a hks evc 5..when this is on I revive a little higher boost of course..If I'm set to hi mode..15psi in 5th gear..though any Lower gears less boost..1st will only ever reach around 9psi.. 2nd 10psi.. 3rd 12psi and 4th can be 13psi and 5th full boost..I can't find any leaks..All hoses have been changed.ive changed my intake as it was custom made and way to short..changed bov incase the turbosmart that came with It was leaking..
New tune on my nistune board by toshi.
Changed spark plugs..coil packs to splitfire.. All hose clamps are tight..
Car has
nistune ecu
z32 afm
Tomei poncams 252
Full 3inch exhaust
Just jap return flow intercooler
Custom metal intake.
Walbro 255 fuel pump
splitfire coils
Large garret turbo. It came with the car and had only about 3k on it. It does have a larger intake connection then a stock skyline turbo..3 inches. So my intake that joints to it us 3inches.. A guy looked up my turbos serial number and was saying may be a gtx garret..It did seem to have double fins on each fin when the intake was installed..
Does anyone have any ideas or why my car has down low boost issues ?.. is there a sensor stopping this or can it be a faulty boost sensor ? Is their anything I can look at with my consult cable to check if anything is maxing out a voltage somewhere ? ...seems some days I can get 1 or 2psi more if km lucky or the car is cold..Thank you
Edited by seriesII
https://www.sau.com.au/forums/topic/459221-r34-gtt-boost-issue-driving-me-nuts/
Oh to add..when I've had it on high boost 15psi. I've seen my turbosmart boost gauge go to 13psi or 14 then it will drop to 10psi in 3rd and 2nd gear..I've had it feel like it launches with power then the boost drops down by 4psi or so and back down to 10psi.. until I hit 5th gear which will hit 15psi. Getting so annoyed with this car..and it's in perfect condition not even a oil drop out of the car
It's has a nistune board installed..not stand engine management.. and was tuned by toshi for 16psi.. so I should get a retune again ,.?.. If it keeps the issue up while tuning I guess it could start costing a bit though..
Toshi is a top notch tuner known by many and one of the best.. even he had this boost issue tuning my car..3rd gear would spike up to 15psi then drop down to 10 psi within 2 seconds.. another tune with this issue seems like it could be a waste of money if I can't find what the issue may be..was unaware the ecu would control boost except for the boost pressure sensor on the 34s.. just seeing if anyone has any ideas I have missed on to why this is going on.
Edited by seriesII
Boost controller seems perfect..well its set up perfect.. I tried a turbosmart the piece.the duel when I got the car..It did the dawn thing. Maby ill hook up the stock solenoid and see what is does ? . I have not tried to presure test..good idea ;)..can any place just do that ?..I guess I would have to take my pipes of ? ..
Gtsboy..that's okay..I had a lot of info ;) .. It is a all in one dump and down pipe..
It does seem when the car is cold..10 mins of warm up and then driving I can get around 9.3psi in 2nd and the other gears.. Once it's a lot hoter seems to not make it to that
Edited by seriesII
You say upgraded intake. Is it all metal? Does it have anywhere it can collapse?
I had a home made snorkel on the standard air box (to allow for the FMIC piping) that was collapsing under the suction created at high boost so I'd go from 18psi down to 0psi at about 5k rpm. Worse in the higher gears since more load / air being pulled in.
Looked at everything before that.. May not be the same issue but worth having a look at your intake, especially pre turbo to make sure there's no weak points
  • Like 1
A smoke test only pressurises the intake to .0001 psi, your leak may only appear at 10psi. I always use a compressor and put 20 to 30 psi in the intake, you would be surprised how many leaks I can usually find.
Do you know what pressure the actuator is supposed to hold?
  • Like 1
Thanks so much for the time to reply guys..so appreciate it... its funny as I have paper work that has just before I bought the car for a new waste gate that is set to 14psi..so wtf..yet max I get is 10psi if I use just the intrenal gate to control my boost :(...I might try this pressure test with a compressor.. Scott when you say intake..would I just remove my pod filter and pop 20psi in there ?..or I could remove the engine oil breather line on my metal intake and pop the compressor in there ? Thanks
Definitely today in first gear using the waste gate with stock solenoid connected..7psi in first.. 8 ish in 2nd and 9psi in 3rd.grr
Edited by seriesII
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
