Hey guys new to the forum and I've started modding my R33 GTST, so I've decided to go with the flex fuel option with the Link G4 ECU that's I've bought.
I've also bought a Walbro 450 E85 fuel pump.
I was recommended to get this fuel rail and injector package by my tuner so I want confirmation from you guys whether or not I should get it.
Mods are: pod filter, front mount, stock turbo (stock boost), 3 inch straight through exhaust with a decat, one hot dog and muffler.
11182225_1038655736147658_76848444121649
For stock plenum. Top feed 1000cc injectors.
Edited by Dan93
https://www.sau.com.au/forums/topic/459479-fuel-rail-and-injector-choice/
Definately the best option going with that for the injectors only thing you will need to change on the aeroflow rail kit to fit the 1/2 size injectors on stock manifold is smaller spacers (8mm) and Orings for the plugs that go into the stock manifold are to big so you need slightly smaller diameter Oring.
Easiest way is talk to Scott on here or look at hes site http://scottyscustoms.com.auhe will sell you the kit with everything ready to bolt in at a good price.
  • Like 1
Ok well the kit consists of everything specifically for the RB25det non NEO, so I would assume that everything that is in that kit is perfect for it.
Has anyone used this kit yet? Also it's $750. Does that seem to be a decent price for what it is?
Quite a bit of money for a modest performance increase (based on running E85) . You will need a retune. Why not wait until you get a new turbo? The new rail is not necessary but if you want one its not that expensive I guess.
Hasn't been tuned yet as that ECU isn't in yet. I'm doing the fuel setup beforehand so it gets done in one go with no retune needed.
What do you mean "I'm doing the fuel setup beforehand so it gets done in one go with no retune needed" ?
Does this mean you plan to drive around for a while with these injectors in without tuning it?
I will either drive the car to the tuner and install it there or I will do it all at home and then get it put on a tow truck and taken to the tuners.
That kit won't just bolt in, not unless they have made different rail spacers. Do you have a link? Where is the kit from?
Also the lower plenum adapters won't fit into the stock plenum without changing the Orings to thinner ones. The rail kits are designed for Greddy plenums.
Ah, Garage7 in the watermark. Ring them and ask? I doubt they will know what you are talking about, and it will be your mechanic's problem when it doesn't fit, which you will have to pay for.
Alright guys thanks for the help. Has anyone dealt with garage7 in Adelaide before? They seem to be pretty damn good and a lot of help.
If you're on Facebook do a search for garage7 and look at their photos. Says it's a solution for stock plenum on rb25dets non Neo conversion from side to top feed.
Just looks like an Aeroflow rail kit to me, unless the pictures don't show the short spacers and second set of Orings?
I can only assume Garage7 are buying the whole kit including injectors from Aznew, which is my supplier, and they don't include either. I need to make the spacers to suit the short 40mm injectors.
Call them and ask, it's the only way to be sure.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
