On carsales the 33's range from $15-35k which is almost 32 price range with the higher priced ones being advertised for a long time.
34's are no less than $45k for the lower end and some of those I wouldn't even bother looking at.
I do agree few years back some dipped to the low $40's but not as of late, haven't really been all that many 34's really.
Could sell your 33 now for $30k also if it was clean.
i'm a bit of a stickler when i scope carsales for 32's to compare mine to have a price in my head of how trends are going and i've rarely seen many that i'd consider clean.
too many poeple have had time to play with it, usually cheap bolt ons, gauge this, gauge that...etc
I've tracked a few seemingly good value R33s, IMO they are extremely slow sellers
There are 2 good buys on the market ATM (in my eyes) for 33's;
1. $24,000 Series 3 ~300kw
http://www.sau.com.au/forums/topic/459263-series-3-r33-gtr-for-sale-melbourne/
2. $20,000 Series 1 - Claimed 78,000 kms - KN6 Grey, stock
post-55803-0-26543600-1442387674_thumb.jpg post-55803-0-89169200-1442387673_thumb.jpg
Edited by squareznboxez
No way are 33s going up and 34s going down lol.
33s are holding steady but take forever to sell. Cheap examples start around 14-15k in WA at least.
34s in WA start around 55+ and that'll get you a white or silver example.
Going to ask owner as to why rear quarter was painted?
Previously I scraped my 33 GTR against a wall parking.. So that quarter had to be repainted....
Edited by 10 4
Agreed with the 34R comment. Have a look on Carsales - There are 17 BNR34's currently for sale, all averaging 50K plus.... Don't know where this rumor of them loosing value has come from
you have more run down 34's that will get on the market (they were around and now most are gone, this was only last year) I saw 3 in the 30's.
Yes the ones that are pristine will fetch the appropriate coin. 2009 was in the 60's and upward for a 34 GTR. Now you are looking at 40's and 50's.
So as more not so good ones hit the market it will be harder to keep a stable market.
Maybe you think I mean they have depreciated over night, yet in reality I mean over a long time and who knows what will happen once the 35 dips below the 100k.
  • Like 1
Yeah been following GTR prices, lowest are essentially 90's high km 09's with some 11' models around the $130k mark.
I've seen what Hadouken is talking about, there was a period where there was many more r34 gtr's and some less desirable ones were asking around $40k but that's gone up since then. $45-50k is the new 40k.
Was surprised there wasn't an abundance of r34 gtr's actually. only 2 in MP and not a great variety of models either (nur, altho there are 2 n1's... go figure)
Yeah 35s are dropping but are steady at 90 ish (aka lots to choose from at 90 so can be had cheaper).
F360s are on the up.
F355s already gone.
996 GT3 already gone.
NSX, gone in Europe, here still ok.
R34 GTR going up in Japan, here still around 45 for silver/white early not great examples.
There was a period yeah of high km crappy ones for low 40s but I think those are gone?
lol yeah, 360's commanding GTR money, despite the brand appeal, I don't think I'd buy one personally.
GT3's 04's 07's all come and go quickly. 04's around GTR money but I really like the 07's - harness and cage? yes please.
Yeah low 40's have come and gone. Now it's $50-60k for 34 gtr's just like $25-30k for bnr32's, i dont really follow 33's.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
