If you've bought one for a GTS-t then it will just drop in
here's a guide I wrote a while back :)
http://www.trak-life.com/diy-nissan-skyline-radiator-replacement-upgrade/
How much clearance did you have when you put the 42mm in ? Enough for a 52mm or just stick to 42 ?
Thanks
about 2cm from the top of the shroud to the fan.. with the 52/3mm radiators people usually grind down the flat part of the fan shroud as that contacts with the fan at high RPM
pic for reference, see that flat area at the top of the shroud, just trim that off and you'll be fine using a thicker radiator...
Cooling system in my 33 is as follows -
ASI aluminium radiator (52mm I think, car isn't here so can't check), Nismo thermostat, GKTech fan with adapter, stock clutch hub and fan shroud, silicone hoses and nulon red coolant. I never see high temps on track, Simple but very effective.
Trust oil cooler and relocation kit, stock rb25 heat exchanger removed and replaced with RB20 Filter mount. Oil temps come up and stay rock solid all day. Also adds probably a litre at least to the oil system, and i add a bit more. Now the engine is coming out, Ill probably add an enlarged gated sump as well. Oil temps are more critical than coolant temps IMO.
7 row power steering cooler with 6an lines. I boiled my power steering fluid previously, now no issues a all.
Car gets hammered every time i drive it, and I don't worry about temps at all.
Racepak has warning lights etc set, but I just drive as hard as i can. Just the concrete walls i need to watch out for.
And as for other stuff needed,
  • check all your other fluids (GBOX/diff/Power steering)
  • a decent set of pads and fluid, I use Project Mu HC+ pads all round, RDA slotted/dimpled rotors, braided lines and Motul RBF600 fluid and I really like it.
  • Check your tyres, may need a better set than what you have now. otherwise check pressures etc.
  • Alignment - may need a more aggressive alignment.
  • a basic set of tools - socket set/spanners/screwdrivers etc. Anything more severe than that usually means going home on a trailer.
  • Maybe have a trailer organised to come get you if need be, or preferably take your car out on a trailer just incase the worst should happen.
  • Remember to have fun - you won't go braking lap record on your first time out, so learn as much as you can, get to know other people out there, ask questions, but above all, have fun.
Oh geez, that's quite comprehensive. The main thing I'm worried about atm is probably the oil, I don't have a cooler or a oil temp gauge. But I'm changing my radiator to a 42mm alloy one, radiator hoses, new coolant, new pads, machining discs, new brake fluid, overfilling engine oil and just checking all the rest
Ya know, add an oil temp gauge if you can and you should be right for the day. May as well add a coolant temp gauge while you're at it. But you could probably suffice without it, just run a cool down lap every second lap.
You could also add a seat and a harness to the list, but once you start... its hard to stop. Do what you can before the day, and go out and have some fun.
Remember to use a TYPE A coolant in the radiator. I use nulon red.
Edited by R31 drift pig
Sorry to bring this thread up again, some people have been saying too much oil can cause hydro lock and that tripped me out. I put 5L all up, it is above the Full line, but is it too much or ?
Hahaha. Hydrolock is basically a motor breathing in water into the cylinders instead of air...............
Too much oil does not cause hydrolock. Its called 'Hydro' as it refers to water. Too much oil can cause other problems but not hydrolock. When people say over fill oil, they're not saying pour in an extra 5L. They are simply saying to add 500ml or so as you will burn oil on the track. Take a 1-2L bottle spare and keep an eye on oil after each run. Top up as required.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
