If you've bought one for a GTS-t then it will just drop in
here's a guide I wrote a while back :)
http://www.trak-life.com/diy-nissan-skyline-radiator-replacement-upgrade/
How much clearance did you have when you put the 42mm in ? Enough for a 52mm or just stick to 42 ?
Thanks
about 2cm from the top of the shroud to the fan.. with the 52/3mm radiators people usually grind down the flat part of the fan shroud as that contacts with the fan at high RPM
pic for reference, see that flat area at the top of the shroud, just trim that off and you'll be fine using a thicker radiator...
Cooling system in my 33 is as follows -
ASI aluminium radiator (52mm I think, car isn't here so can't check), Nismo thermostat, GKTech fan with adapter, stock clutch hub and fan shroud, silicone hoses and nulon red coolant. I never see high temps on track, Simple but very effective.
Trust oil cooler and relocation kit, stock rb25 heat exchanger removed and replaced with RB20 Filter mount. Oil temps come up and stay rock solid all day. Also adds probably a litre at least to the oil system, and i add a bit more. Now the engine is coming out, Ill probably add an enlarged gated sump as well. Oil temps are more critical than coolant temps IMO.
7 row power steering cooler with 6an lines. I boiled my power steering fluid previously, now no issues a all.
Car gets hammered every time i drive it, and I don't worry about temps at all.
Racepak has warning lights etc set, but I just drive as hard as i can. Just the concrete walls i need to watch out for.
And as for other stuff needed,
  • check all your other fluids (GBOX/diff/Power steering)
  • a decent set of pads and fluid, I use Project Mu HC+ pads all round, RDA slotted/dimpled rotors, braided lines and Motul RBF600 fluid and I really like it.
  • Check your tyres, may need a better set than what you have now. otherwise check pressures etc.
  • Alignment - may need a more aggressive alignment.
  • a basic set of tools - socket set/spanners/screwdrivers etc. Anything more severe than that usually means going home on a trailer.
  • Maybe have a trailer organised to come get you if need be, or preferably take your car out on a trailer just incase the worst should happen.
  • Remember to have fun - you won't go braking lap record on your first time out, so learn as much as you can, get to know other people out there, ask questions, but above all, have fun.
Oh geez, that's quite comprehensive. The main thing I'm worried about atm is probably the oil, I don't have a cooler or a oil temp gauge. But I'm changing my radiator to a 42mm alloy one, radiator hoses, new coolant, new pads, machining discs, new brake fluid, overfilling engine oil and just checking all the rest
Ya know, add an oil temp gauge if you can and you should be right for the day. May as well add a coolant temp gauge while you're at it. But you could probably suffice without it, just run a cool down lap every second lap.
You could also add a seat and a harness to the list, but once you start... its hard to stop. Do what you can before the day, and go out and have some fun.
Remember to use a TYPE A coolant in the radiator. I use nulon red.
Edited by R31 drift pig
Sorry to bring this thread up again, some people have been saying too much oil can cause hydro lock and that tripped me out. I put 5L all up, it is above the Full line, but is it too much or ?
Hahaha. Hydrolock is basically a motor breathing in water into the cylinders instead of air...............
Too much oil does not cause hydrolock. Its called 'Hydro' as it refers to water. Too much oil can cause other problems but not hydrolock. When people say over fill oil, they're not saying pour in an extra 5L. They are simply saying to add 500ml or so as you will burn oil on the track. Take a 1-2L bottle spare and keep an eye on oil after each run. Top up as required.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
