Well if its a piston ring or something it is in to some serious time/money to refresh and depending on how long the other guy ran it could be one hell of a head ache.
Hope it is just the HG then you will be away laughing.
Even with that shitty compression the engine should still start and run. (will probably be rough). If it was mine, I would persevere in getting the thing started, just to get a bigger picture of the overall condition of everything else and then making a more informed decision on wether to fix or part. As said a hg is your best hope and may or may not be the issue. I have replaced one before, it is a time consuming job but not all that difficult, there are plenty of guides online and if u can get someone with some mechanical knowledge and tools to lend a hand it is very do able.
good news !! i got it started !! although it ran rough. had to keep foot lightly on accelerator otherwise i recon it would of conked out.thing is loud as hell lol
i couldnt rev it past 2500rpm (somewhere around that mark ) is that due to compression or using stock ecu with 800cc injectors and no afm,,or both lol
im just happy i got it started.ill put more fuel in, i noticed the fuel light was still on when i started. for some reason fuel pump wasnt giving me a reading after putting fuel in and turning ignition on ( maybe from having it unplugged ? )
not really sure where to go from here
also when i reved to 2500rpm it pretty much stayed there. sounded like fuel cut or something. so im guessing thats from using stock ecu ?
minds racing right now thinking what to do now lol
ok thats what i figured. i cant really spend anymore money for a few weeks now. so i;ll google how to set up the vipec ecu. assuming its not damaged. it was giving 2 error codes last time i checked but they werent serious ones from what i remember.anyone have any links on how to set it up ? i could print screen my laptop while using the software and maybe someone will notice what wrong in the setup ?
you're welcome... lol i talked to someone at vi-pec and this is the reply i got " Unfortunately I am going to be the bearer of bad news. There is almost a 100% chance the reverse voltage will have damaged the ECU. When this happen it often takes out the ignition drives and the Aux output drives often with extensive PCB damage. Best bet for a start will be to open the ECU and see how bad it looks. If the PCB has damage it could be a costly repair"
so i guess i'll be opening up the ecu tomorrow and i'll take a photo and send it to him. but not liking my chances. sucks cause that's an exspensive ECU :(
definitely cant afford a new one for awhile which sucks.
New ecu and engine rebuild.
Then see if clutch and gearbox, brakes and suspension are ok.
Have you checked to see how rusty the chassis rails are yet.
Supposing that its repairable what are your chances of finding the person who tuned it last and seeing if they have the tune saved on their computer? If so that would be a good starting point to get it running.
I think we have proof that the ECU suffered. Only having some of the coils working is a solid indicator. That would tend to suggest that the ECU may need to be considered no longer useful. From that point, the question becomes.....what do you do now?
Fixing the ECU probably really means a whole new board rather than hours spent replacing components, testing and hoping that there isn't other damage hidden in there waiting to pop up once it starts working properly. A whole new board has got to be a large % of the whole ECU price.
You have a stock ECU and could Nistune it, but that is $ and then you'd need AFMs which adds more $$.
And then you have at least a head gasket, possibly other detonation damage, etc etc.
Parting the car might be the smartest option.
I agree, you have an RB26 with issues and a damaged ECU both of which are going to cost cubic dollars to fix properly.
Part it out and buy a runner, you'd be surprised how much you'll get for the components.
Hrrm I'm not sure what to do now. And for parting it out. I wouldn't know what to put prices on everything and I can't be bothered taking it all apart either lol. Well I'll check the ecu tomorrow and take a pic and go from there.ill look into nistune too see how to see how much. I had my bluebird ecu nistuned. Don't remember it costing that much. I have a z32 afm if that's possible to use
I started the car again earlier to make a video. It wouldn't start unless I primed the fuel pump a couple of times. Not enough fuel pressure or something? Was getting a couple of little backfires whole idling too. Probably a bit of shitty fuel? I don't know my brain hurts from all of this lmao
I'm putting the video on YouTube soon and I'll post the link
You can look through the for sale ads here to see what people sell parts for. You'll get shouted down if people think you're too expensive and you'll get dozens of PMs if your prices are low.
It's not that Nistune is expensive, but by the time you buy the board and get it fitted, then tuned, you're looking at >$1k. So you have to factor that into your comparison against trying to make the Vipec work. And you can't use a single Z32 - you need 2.
With respect to the car running.....this seems to be surprising given how many coils you supposedly didn't have working. If I had a 6 cylinder with only a couple of cylinders firing, I would hesitate to call running "running" and my language about backfires/pops and throttle blips would likely be a lot stronger than yours. Maybe your ECU is not as borked as we fear.
all coils are working with the stock ecu. i didnt try start it with the vipec since i knew it was only sparking on 1 or 2 cylinders. i changed all the spark plugs after i did the compression tests too.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
