I hooked up an oil temp gauge b4 fitting the cooler just to see what the oil was doing. On a 20 deg day oil temp was sitting between 87-90 degrees. I did the same test with the cooler fitted and temp was around 74. I then blocked airflow to the cooler and ran the test again and got 84-86 which I'm comfortable with. I will monitor this when winter comes and see if a thermostat will be required. The oil lines in the kit where way too long, at this stage I have just found an interesting route to run them along and have covered the areas that would rub on anything with foam padding. Once I work out exactly what I'm going to do come winter time I will then cut the oil lines down to the exact required lengths. Will be interesting to see how this budget kit performs on the track. If all goes well I will find out on Jan 30 at Sandown.
I have also ordered a China alloy rad and should see that in the next few days. That will complete the cooling mods. I'll just be left with finishing with the brakes, installing the white line swaybar kit and some castor arms with offset poly bushes I've got lying around. That will complete this round of mods. For the next round im contemplating a hicas eliminator and some front camber arms.
Nice work Bill!
Funny you are getting hicas elim and front camber arms - I'm ordering hicas elim and REAR camber arms this week lol. Going to get the kits from Otomoto if that helps you at all!
What radiator are you getting? I was looking at the china worley ones form fleabay :D
Nice work Bill!
Yeah, eBay spec rad. ASI brand. I'm pretty sure all those alloy rads asi, worley, gp1 and so on all come out of the same factory. I bought the asi one as that seller seems to sell a lot of them and most customers are happy. I will look into otomoto down the track for the other bits. Cheers Jacob.
All the eBay radiators are the same, ASI, Worley, GPI, the welds all look the same and the top tank has that ridge.
They work pretty well for street use, drags, and moderate track use with moderate power. I only starting having some slight overheating issues once I started making some decent power and mind you that was on a 37 degree day on the track.
Other than that, I've done track days in Autumn, Winter, Spring with the same power and the car will power down 8~10 laps without the water going more than 105 degrees.
  • Like 3
^Just as I suspected. All from 1 big China sweat shop. Thanks for the run down of their performance Johnny. Pretty much mirrors my experience with them on my old s15 and since I'm at best an amateur wannabe racer I think the rad will fit the bill perfectly:D
Thanks guys, good to know they are all the same. I thought my car was hot the other day hauling ass up the mountains LOL got to 95 and I was freaking out lol. 105 jesus.
Let me know how you go with the rad Bill. Johnny is the one who inspired me to look at getting one also :D
I've seen my car hit 115 degrees water but I was doing a hotlap so I hit the mute button LOL...
Car still lives, radiator still not warped and more boost going into it when I get my new turbo (after I get off my arse and send my old one back in) haha
Just make sure you flush out the radiator properly and before you do all of that make sure you sand down the fittings on the radiator or your stock overheat fan thermoswitch won't sit flush... I found out the hard way LOL...
Screwed it in, noticed the slight gap, installed it into car.. filled it up... bam... leak... removed radiator, removed swtich, sanded it down with a block, re-installed and bam no more.. been going hard for 3 years.
  • Like 1
For both of us ;)
Can either of you confirm what size is the biggest you can go and still fit the fan shroud?
I'm not really sure to be honest. I just bought one that said direct fit. Core size is 400 x 650 x 52mm. I'll have to measure the external size once it arrives. I'm pretty sure all the eBay ones are the same size regardless of what the seller claims. Some say 40mm core some say 52mm. Can't believe anything these days. We'll see what turns up. Lucky dip:lol:
43mm thickness, and that gives you approximately 1.5cm clearance between the fan shroud and fan blades.. however there have been incidents where at high RPM the fan flexes just enough to smash into the shroud.. I believe this happened to SimonR32 on this forum.
Best way around is to trim off the flat area of the fan shroud
Thanks guys and sorry to hijack the thread Bill!
My mate had stock fan and stock rad with shroud and went through two radiators in the space of 4 days (and 500 worth of towing) because of an unbalanced fan (slightly bent fin) then when it spun up at RPM it caught the shroud and went into the top off the rad lol.
Anyway - Carry on gents
Yum cha radiator arrived and was fitted yesterday. All went well. Thanks to johnny for the tip about sanding the fitting at the bottom, the sensor still wouldn't sit flush so I put a fat o ring on it and that was that. No leaks. Was a tightish fit but fitted well. Only issue is my factiry cai inlet just fouls on the back of the fan cover so needs a slight trim or slight movement of air box. Bleeded and taken for a couple of drives since. Temp is sitting at 86-87 consistently.
Pic of finished product.
Also did the rear brakes today. Same deal as the front, Nissan pads where still in there and there discs where almost factory size. Measured up at 17.8mm so I left the discs on and fitted the qfm hpx pads. So I've got a1rm on the front and hpx on the back. Why the mismatch u ask? I paid 55 per end and that's what I managed to secure. I also replaced and bled the fluid with penrite 10 tenths. While I had the car on the stands I also put on some different castor arms I had with offset poly bushes. My car still had the factory bushes. Wtf its like nothing has ever been changed on this car. Lol.
Tomorrow I'll get around to putting the white line swaybar kit on.
Nice work - So the radiator fit with the fan shroud?
be careful with those caster arms, I got stung by a shop I will not name for a big alignment bill because (speaking from the aligners perspective) "Everytime I had to make an adjustment, I had to pull the alignment tools off then take off the arm then put everything back on and repeat till it was right"
The bill was significantly more than I was quoted despite me telling them what setup I had. None the less the alignment was great so I'm not complaining.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
