Well guys the time has finally come for the event everyone has been looking forward to!
It is our Putty Road Cruise up to Singleton!
Date: Sunday 13th of December
Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC
Meet Time: Meet at 9:00am for a 9:30am departure
Destination: The Royal Hotel, Singleton
Map: https://www.google.com.au/maps/dir/-33.6257063,150.8382563/-33.60192,150.8219818/7755+Putty+Rd,+Garland+Valley+NSW+2330/Royal+Hotel-Motel,+84+George+St,+Singleton+NSW+2330/@-33.0283837,151.3019527,10z/data=!4m16!4m15!1m0!1m0!1m5!1m1!1s0x6b0cfd0f940d6db7:0x818eda6b9975306!2m2!1d150.748518!2d-32.9074811!1m5!1m1!1s0x6b0cafd7fd5df341:0xb21f7907d7a5223e!2m2!1d151.1759855!2d-32.5629127!3e0?hl=en
We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road.
From this we will stop at the Halfway Truck Stop which we should reach at approximately 11:30am.
For all the Newcastle folks this will be a good point to join up.
From here we will continue on to Singleton for lunch.
Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton.
At Singleton there is a range of servo's available including BP, Shell and Caltex.
There will be a lead and follow car so no one should get lost.
We will also be bringing along walkie talkies to keep the group together so if you have one please bring it along.
If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior!
This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days.
This is an official SAU:NSW event and will be run under a CAMS permit.
One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general.
When attending one of Skylines Australia NSW events please try to:
• Be aware of surrounding environment and act accordingly.
• Drive courteously on the state’s roads as a true enthusiast should.
• Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly.
• Any misbehaviour will not be tolerated and you will be asked to leave.
Thanks guys and hope to see you there!
Attendees:
1. RBrennan25 +2
2.
3. Terry_GT-R34
4. crashdown
5. GTofuS-T
6. Grease
7. BenRThirtyFour
8. Mihalis
9. Dark26
10. pureplaya
11. sammi_d
12. Yo-Yo
13. Murray_Calavera +1
14. Aqua
15. CaptainFresh +1
16.
17. BunsenBurna
18. stagea pete
19. rosella +1
20. SiNNO
21. chriszila +1
22. Victory
23. Clinton
24. PR34CH
25. Fdawgg +1
26. roy8532
27. anthony_rs4s
28. Bodella
29. bluenoir +1
30. NISMO
31.
32.
33.
34.
35.
In the process of getting that day off so pop me in please Chris!
Do we have an idea what date the January meet will be?
At the moment we are still finalizing the date due to New Year Holidays, School Holidays and Public Holidays.
Rough date would be weekend of 23rd + 24th but yes need to confirm.
This was taken from the exact same cruise 2 years ago.
https://www.youtube.com/watch?v=ru2WUf1SuxA
Adam can I put your name down for this?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
