Hi all
Long time no boost.
Time to feel the rush again. this time not just a stock rb25det with intercooler.
I have an apparent F6 Turbo im puttin on my forged RB30 today, i think its BB but not 100% sure & i want your advise.
Features:
6 bolts either side
spins around 13 seconds after blasted with air gun
looks like restrictor in top oil feed but its 3-4mm
pics attached
BTW what do you think of a 5" dump pipe i made for this performance wise ?
Cheers
Ball bearing turbo's don't need a lot of oil flow, and the GT35 likes to burn a little oil if the feed is opened up from my experience. I would start with a 1mm restricted AN fitting for the feed and see how it goes.
A filter in the feed line is a good idea, not a little pissy one, a larger stainless mesh filter to take out any crap that may block the 1mm hole.
Pretty sure the F6 still ran a 3 inch inlet, so this would be an aftermarket GT35, do you have some pics of the dump flange side?
Yep, Falcon GT35 didn't have a large inlet but they did have that smaller A/R. Maybe it changed at some point?
Unless you change the front A/R and aiming for 380rwkw, bit of a poor turbo choice IMO.
Better off with a GT30 with a 1.06 AR if 300rwkw-330rwkw is the goal, even a .82 works well, comes on early and hard though so you need a decent investment in tyres/diff/suspension
  • Like 1
Cheers guys i called up honeywell & gcg, they said max oil pressure of 45 psi to the turbo for this one, it has a restrictor built in around the corner from oil feed but still needs 1mm restrictor pre turbo so i bought one thursday arvo.
Yeah i was thinking of getting an inline oil filter as enzed didnt stock any when i got the restrictor. so i will order one online thanks.
This turbo came on a spag manifold with a plated vl turbo with lots of mods, forged, int, fullspool, 31 spline billet axles etc etc. and LOTS of spares all for 2.5k.
i just had to make it work IE make dump/ lines/ spacer etc it gets rego this week.
This turbo is better then no turbo so i slapped it on i know its a fair upgrade from a stock rb30 turbo that pumps a pissant 150 kw, this one pumps 310kw so im expecting laggg etc. I dont know heaps about them but ill test it. then change it if i dont like it, next is comp & tune.
what turbo would you suggest for rb30 300 kw give or take ?
what sort of power can these boost to safely 400kw ? more i guess
Turbo exit pic attached
With the current turbocharger you have. Run it with a .82 rear housing, should see pretty responsive 360rwkws mark. The next size up would be a GTX3582, or just fit a GTX3582 wheel to your current CHRA.
GT30 as I said above for 300-330.
You can get 400rwkw on E85 with the current turbo you have. The XR6 GT35s always seem to be a tad shorter on the power, probably the compressor A/R at the upper end making a slight difference. Overall compressor A/R doesn't make that much difference, turbine far more important.
If you are going E85, get a GTX series. If you are staying on PULP then the GT series are the better choice IMO. GTXs only really shine at the higher boost ranges (talking 20psi++)
Really depends what the use will be, it's too large for the street if you want response, but as a track turbo it would work well imo.
I much prefer a smaller turbo and leaning on it harder (for the street) but a 3L should spool the GT35 up nicely anyway.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
