He is saying the left over petrol will cause it to read a lower ethanol content which will make the sensor wind back the tune (reduce timing) even though the contamination is so little it won't effect the knock resistance of the e85
  • Like 1
Can't be bothered finding the paper, but basically for port injected engines of our vintage there is no additional knock benefit past E40. So really your timing map should alter from E0 to E40 and your fuel map should alter from E0 to E100. I bet the Wolf (like most others on the market, to be fair) isn't smart enough to do this. So rather than make a video about it they could improve their ECU to solve the problem they are talking about.
OTOH, because the ignition map is still scaled to E100 same as the fuel map you lose out on a little bit of ignition timing if you are swapping fuels. Big deal. You're in it for the convenience, right? You still get it, right? Who cares!! The people who are in it for the last 1% of performance are running full E85 conversion, not flex.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
