yep if that op6 has a nylon wheel on it get a coke can and take the shaft space up with that so your steel or alloy wheel will fit snug as, if they leak which all the nissan ones do
run fuel straight through it run the return back to tank, it works a bit like an extra injector, and will throw a top grade flame out of the exhaust, i was thinking that op6 you have
will ya swap a house and land package for it, gee wiz it sounds like it goes, and i wont ever have to fix a motor again with that op6 turbs, forget the v8 to complicated
i got a starfire at home twice the power and strength, if ya still not sure about no 5 but its running ok take the plug out and poor ajax down the plug hole always
fixes bottom ends thats what the best machine shops use
dont shot it that wont fix it, dont get mad just get ya good mate to fix her up
Wow you guys on this forum really are f**ked hey, you guys look so retarded its like theres a room full of you faggots holding each others cocks taking a turn at a typo war (long term forum faggots vs rb30t) sounds like you all have a lot of baggage & hate from your previous f**ked up inexperiences with cars ha ha, down to the point where its easier to writes masses of junk hating then a sentence of being helpful.
I fixed the problem weeks ago without your help.
Oh thats rite im new to the forum youd better gang up on me n hate cause ive never seen that before or fixed a car...........................not
Peace fools
  • Like 1
Peace fools
100% back you up on that.....
Peace fools
Nah mate I am serious, I couldn't understand wtf was being said, sorry to offend but I was only saying the truth.
So did you use ajax to fix the problem because I am really interested to know what you use ajax for to find a problem with an engine. How did u fix the problem anyway?
Can you please type it in point form so I can understand it because obviously I am not accustom to comprehending modern modified English.
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
