yep if that op6 has a nylon wheel on it get a coke can and take the shaft space up with that so your steel or alloy wheel will fit snug as, if they leak which all the nissan ones do
run fuel straight through it run the return back to tank, it works a bit like an extra injector, and will throw a top grade flame out of the exhaust, i was thinking that op6 you have
will ya swap a house and land package for it, gee wiz it sounds like it goes, and i wont ever have to fix a motor again with that op6 turbs, forget the v8 to complicated
i got a starfire at home twice the power and strength, if ya still not sure about no 5 but its running ok take the plug out and poor ajax down the plug hole always
fixes bottom ends thats what the best machine shops use
dont shot it that wont fix it, dont get mad just get ya good mate to fix her up
Wow you guys on this forum really are f**ked hey, you guys look so retarded its like theres a room full of you faggots holding each others cocks taking a turn at a typo war (long term forum faggots vs rb30t) sounds like you all have a lot of baggage & hate from your previous f**ked up inexperiences with cars ha ha, down to the point where its easier to writes masses of junk hating then a sentence of being helpful.
I fixed the problem weeks ago without your help.
Oh thats rite im new to the forum youd better gang up on me n hate cause ive never seen that before or fixed a car...........................not
Peace fools
  • Like 1
Peace fools
100% back you up on that.....
Peace fools
Nah mate I am serious, I couldn't understand wtf was being said, sorry to offend but I was only saying the truth.
So did you use ajax to fix the problem because I am really interested to know what you use ajax for to find a problem with an engine. How did u fix the problem anyway?
Can you please type it in point form so I can understand it because obviously I am not accustom to comprehending modern modified English.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
