Don't put a 2.6 crank in. Pay the coin and out a 77.7 or larger in.
You can still put the Pistons in depending on rod length. The HKS 2.8 uses stock length Rods (121.5mm) for the 2.8.
*Tomei use 119.5 mm rods for a 77.7 2.8 stroker.
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7657944
awesome soo i can use my rods? on an 2.6 build?
Rods will be fine to re use though.
What's actually wrong with the crankshaft?
mechanic put the lines on the oil relocator kit wrong soo it was pumping threw the outlet and passing threw the inlet dame shame too here are some pics of the car, when we opened up the mains were gone, thank god my reimax oil pump was still good my head fine, ive got an hks built head on the car, i was looking at the step 0 hks crank its only 1900 dollars i think im going to go with that
12312422_10156309487640182_69799159_n.jp
12348182_10156309487685182_760042887_n.j
12278068_10156309487630182_816281595_n.j
12336219_10156309547425182_924797934_n.j
Edited by Regan2860
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7657969
So the mechanic owes you a new crank then right? That's a noob error.
unfortunately he would owe me a hks step 2 crank and a gt block... but thats like what ? 8 thousand dollars? he doesnt make that in a year, 3rd world country man, im just going to put a stock freshened up short block, goin to tune it down from 750whp to 550 witht the water meth injection low timing itll last years, i have to sale the car anyways moving to austin texas, got an awesome job at boostlogic, wana hop into an r35 as soon as i get their
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7658421
He doesn't have insurance?
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7658459
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
