everyone start looking for a new set of front guard for duncan he loves the biffo!!!!!
werd. I have a memory of duncan at turn 1+2 Oran GP track in a daewoo. oh the carnage....
hehehe.
  • 4 weeks later...
SAU Nickname: jlnewton
Car Make and Model: R33 GTR V-spec
Circuit Name: Queensland Raceway - Clubman layout
Lap time: 1:03.15
Modifications
Engine: RB26DETT
Power: 196.7awkw
Suspension: Apexi T-max coilovers with king springs (F 400lbs, R 225lbs), Whiteline front camber bush and pineapples, Cusco adj caster rods and rear camber arm.
Tyres: Dunlop DO2G 235/45 R17
Brakes: Brembos with slotted DBA 4000s front and rear, Hawk Pads front and rear, Braided Brake lines front and rear, Motul fluid and cusco brake cylinder stopper.
Body weight: ????
First time I have run on anything other than road tyres, damn what a difference! Slashed 2.4s of my previous best, unbelieveable difference in grip level.
I did a supersprint at EC yesterday and managed to better my previous best by more than 3 seconds. Funny thing is the car is exactly the same as last time I was there except for rear camber pins and a decent wheel alignment. Goes to show the value of a good wheel alignment.
Best time of 1:51.6 and full results are shown here:
http://www.natsoft.com.au/cgi-bin/results....08/2005.EAST.S1
I managed to beat all other WRXs on street tyres as well as all runners on R-spec tyres as well. The only WRXs to beat me were on slicks running increased capacity (2.2 and 2.5 L engines). All in all a great day at the office! :lol:
There was one VERY fast white GTR running too. Man that thing was quick!!! John was there in the very boosted Zed but judging by his times something was amiss.
Anyway here's the list of specs and mods again:
Modifications
Engine: HiTech 3" SS turbo-back, retuned stock ECU
Power: Dunno-about 170kW ATW
Suspension: Stock with 20mm lower Pedders springs, 22mm rear swaybar and rear camber pins
Tyres: Standard 05 STi Bridgestone RE070
Brakes: Stock Brembos with DBA4000 rotors, DS2500 pads and Castrol Super Response DOT 4 fluid.
Body weight: Pretty much stock STi-not sure.
Well done Ben that's a great time for a hyundai :P
Here's what I did the other weekend:
SAU Nickname: Duncan
Car Make and Model: R32 GTR N1
Circuit Name: Oran Park GP
Lap time: 1.21.2
Modifications
Engine: Standard
Power: not sure yet, standard boost and factory ECU not tuned
Suspension: some jap coilovers
Tyres: Yoko A032R 245/45/17
Brakes: standard (brembos) with hawk pads and lucas fluid
Body weight: 1500
I'll have some wakefield times after this weekend, have to beat Gary's car this time :D
SAU Nickname: AzzurrA
Car Make and Model: R32 GTS-t
Circuit Name: Queensland Raceway - Clubman Circuit - 2.11km
Lap time: 1:09.86 (20/08/05)
Modifications
Engine: K&N Pod Filter & 3" Turbo Back Exhaust
Power: 131.7kw @ Wheels
Suspension:
* Bilstein Shocks
* Kings 'Low' Springs
* Whiteline Adjustable 24mm Front Swaybar
* Whiteline Adjustable 22mm Rear Swaybar
* Whiteline Adjustable Front Camber Bushes
* Whiteline Adjustable Castor Bushes
* Whiteline Adjustable Rear Camber Bushes
* Whiteline Lock & Align Kit (Set up for handling)
* Urethane Lower Control Arm Bushes
* Hicas Lock Bar
Tyres:
* Front: Falken Azenis RT-215s 205/55/16
* Rear: Toyo Trampio GU:WN 205/55/16
Brakes:
* Standard R32 GTS-t M-spec calipers & Rotors
* Motul RBF600 Brake Fluid
* Race Brakes RB74 Compound Brake Pads (Front
* Generic crappy pads rear
Body weight: Full Street Trim (Including Spare Tyre in Boot)
following up from ben that gtr was greg from autosport it was hooking
696 Greg Boyle SSCC Nissan Skyline SVD 24 4 1:48.1900 0:06.1600
only reason i bring this up was cause
John Penlington SSCC 4D 5 4 1:49.6400
seems the slot car got hossed by a street gtr lol
great time gonads (shame you drive like a girl)
anyway i did a good time up and over the hill 3 donuts on the way down and got the hell out of there before being arrested (PB for myself)
love your work pete. next time should be good for 4 or 5 donuts pre-incarceration...noice.
yeah, Greg certainly knows his way around eastern creek. his car fairly hammers too.
I did a supersprint at EC yesterday and managed to better my previous best.......
Hey good work Nads - do you still take turn 8 flatstickfullycrossedupfacingthefarkingconcretewall or have you found a more exciting way round it?
Edited by Bonkers
niccce
good to see a vg car getting its tits thrashed off it
Well done Ben that's a great time for a hyundai ;)
Thanks Duncan. I'm pretty happy with my effort.
Howdy Bonkers! I've graduated from taking turn 8 as "flatstickfullycrossedupfacingthefarkingconcretewall" and now I'm trying to take turn 1 the same way. :) Seems to have worked reasonably well.
I've gotta admit I was shown my way around Eastern Creek by an absolute master! Since the 1/2 day I did with you I've only done 1 other full day at Eastern Creek so maybe I was listening to your pointers?
None of this sticky tyres crap either. Go the street tyres!
So when are you guys coming out to Orange?
Cheers,
Ben
Car Make and Model: R33 GTSt
Circuit Name: Mallala
Lap time: 1m25s
Modifications
Engine: stock rb25det
Power: ran @14psi (unknown exact rwkw), but makes 265rwkw @16.5psi
Suspension: bilstein sports plus kings 1inch lowered
Tyres: RE55s
Brakes: Stock setup using 4000rotors front and EBC greens.
Body weight: stock
Was first time on a track and only ran 2 short sessions so pretty pleased with the time :P
Washing off some speed before throwing her hard into turn one (had the most fun throwing into this corner a bit overspeed then trying to catch the tail before hooking round the hairpin :huh:)
Edited by SLY33
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
