SAU Nickname: Bass Junky
Car Make and Model: 1998 Nissan Skyline R34 GTT
Circuit Name: Winton Long Track
Lap time: 1.45:4270
Modifications
Engine: PowerFC, Boost Kit, Full Exhaust
Power: <200rwkw
Suspension: Whiteline Springs, Koni Shocks, Whiteline Sway bars, all alignment stuff
Tyres: Hankook Ventrus Sport K104
Brakes: Stock, Bendix Ultimate Pads
Body weight: Stock
SAU Nickname: Abo Bob
Car Make and Model: 1999 Nissan Skyline R34 GTT Auto
Circuit Name: Wakefield Park
Lap time: 1:12.45
Modifications
Engine: Chipped ECU, GCG Highflow, Full Exhaust, 480cc injectors
Power: 228rwkw
Suspension: Stock
Tyres: RE55's
Brakes: Stock
Body weight: Stock 4 door
Took 0.2s off PB at Winton on Sunday (1.35.0). Should be able to get into the 1.34's next time on the condition it a) it dry and B) I'm not full of Benalia Wang Busters from the night before.
Have both Calder and PI in the next few weeks so will hopefully improve times for both tracks.
hey Roy you have any times for Mallala yet?
I will be there shortly... :)
Not yet...will be looking at doing a day in November when everyone is a little more organised...including me... http://www.skylinesaustralia.com/forums/in...ic=46214&st=100
Updated times...
And Abo Bob, so you only saw a 2sec improvement with the RE55s??? Still a huge improvement, but do you think that semis are worth 2seconds, or were there problems on the day which meant you couldnt get the most out of the tyres?
I improved by 3 seconds actually. 1:15 to 1:12. I also have about 30 more rwkw but my new transmission is a bit different than the old one which required some learning.
I would say that I'll get a 1:11 next time down with current setup but I have some bilsteins waiting to go in, still got stock suspension. I'd love to do a 1:10 in an auto.
Howdy fellas,
Did a supersprint on sunday at Wakefield and got my best time down to a 1:10.63.
Results are here:
http://www.natsoft.com.au/cgi-bin/results....09/2005.WAKE.S1
All guys above me were running slicks or R-spec tyres. I'm on stock 05 STi Bridgestone RE070s. I'm getting very tempted to try a set of stickies.
...Ben
SAU Nickname: jlnewton
Car Make and Model: R33 GTR V-spec
Circuit Name: Queensland Raceway - Clubman layout
Lap time: 1:03.15
Circuit Name: Queensland Raceway - Sprint Layout
Laptime: 1:00.96
Modifications
Engine: RB26DETT
Power: 196.7awkw
Suspension: Apexi T-max coilovers with king springs (F 400lbs, R 225lbs), Whiteline front camber bush and pineapples, Cusco adj caster rods and rear camber arm.
Tyres: Dunlop DO2G 235/45 R17
Brakes: Brembos with slotted DBA 4000s front and rear, Hawk Pads front and rear, Braided Brake lines front and rear, Motul fluid and cusco brake cylinder stopper.
Body weight: ????
...for all the guys with the r33 gtr's how do they compare to cars such as type-r's, s2000's, sti's, and evos?
Unless they are serioulsy modded, almost std GTRs with semi slicks leave them for dead. The EVOs seem to get close at some tracks, but not close enough...hell even my little GTST keeps the late model hatch/hairdresser brigade honest :D
And storms to the top of te Queensland Raceway time card :D
SAU Nickname: captainah
Car Make and Model: 1995 GTR V-Spec R33
Circuit Name: Sandown
Lap time: 1:30
Modifications : 0.95bar, 4" exhaust, pod filters, pump & surge tank, fmic
Engine: stock
Power: 217awkws
Suspension: stock v-spec (hard!)
Tyres: 245/45 17 bridgestone S02
Brakes: R33 stock (brembos)
Body weight: stock
Car Make and Model: 1992 GTR R32
Lap time: 1:35
Modifications : 0.95bar, 4" exhaust, pod filters, pump & surge tank, fmic, unichip piggy back computer
Engine: stock
Power: 205awkws
Suspension: stock - oversteer city
Tyres: 245/45 17 cheapies
Brakes: stock (didn't cope well!)
Body weight: stock
Edited by captainah
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
