SAU Nickname: Bass Junky
Car Make and Model: 1998 Nissan Skyline R34 GTT
Circuit Name: Winton Long Track
Lap time: 1.45:4270
Modifications
Engine: PowerFC, Boost Kit, Full Exhaust
Power: <200rwkw
Suspension: Whiteline Springs, Koni Shocks, Whiteline Sway bars, all alignment stuff
Tyres: Hankook Ventrus Sport K104
Brakes: Stock, Bendix Ultimate Pads
Body weight: Stock
SAU Nickname: Abo Bob
Car Make and Model: 1999 Nissan Skyline R34 GTT Auto
Circuit Name: Wakefield Park
Lap time: 1:12.45
Modifications
Engine: Chipped ECU, GCG Highflow, Full Exhaust, 480cc injectors
Power: 228rwkw
Suspension: Stock
Tyres: RE55's
Brakes: Stock
Body weight: Stock 4 door
Took 0.2s off PB at Winton on Sunday (1.35.0). Should be able to get into the 1.34's next time on the condition it a) it dry and B) I'm not full of Benalia Wang Busters from the night before.
Have both Calder and PI in the next few weeks so will hopefully improve times for both tracks.
hey Roy you have any times for Mallala yet?
I will be there shortly... :)
Not yet...will be looking at doing a day in November when everyone is a little more organised...including me... http://www.skylinesaustralia.com/forums/in...ic=46214&st=100
Updated times...
And Abo Bob, so you only saw a 2sec improvement with the RE55s??? Still a huge improvement, but do you think that semis are worth 2seconds, or were there problems on the day which meant you couldnt get the most out of the tyres?
I improved by 3 seconds actually. 1:15 to 1:12. I also have about 30 more rwkw but my new transmission is a bit different than the old one which required some learning.
I would say that I'll get a 1:11 next time down with current setup but I have some bilsteins waiting to go in, still got stock suspension. I'd love to do a 1:10 in an auto.
Howdy fellas,
Did a supersprint on sunday at Wakefield and got my best time down to a 1:10.63.
Results are here:
http://www.natsoft.com.au/cgi-bin/results....09/2005.WAKE.S1
All guys above me were running slicks or R-spec tyres. I'm on stock 05 STi Bridgestone RE070s. I'm getting very tempted to try a set of stickies.
...Ben
SAU Nickname: jlnewton
Car Make and Model: R33 GTR V-spec
Circuit Name: Queensland Raceway - Clubman layout
Lap time: 1:03.15
Circuit Name: Queensland Raceway - Sprint Layout
Laptime: 1:00.96
Modifications
Engine: RB26DETT
Power: 196.7awkw
Suspension: Apexi T-max coilovers with king springs (F 400lbs, R 225lbs), Whiteline front camber bush and pineapples, Cusco adj caster rods and rear camber arm.
Tyres: Dunlop DO2G 235/45 R17
Brakes: Brembos with slotted DBA 4000s front and rear, Hawk Pads front and rear, Braided Brake lines front and rear, Motul fluid and cusco brake cylinder stopper.
Body weight: ????
...for all the guys with the r33 gtr's how do they compare to cars such as type-r's, s2000's, sti's, and evos?
Unless they are serioulsy modded, almost std GTRs with semi slicks leave them for dead. The EVOs seem to get close at some tracks, but not close enough...hell even my little GTST keeps the late model hatch/hairdresser brigade honest :D
And storms to the top of te Queensland Raceway time card :D
SAU Nickname: captainah
Car Make and Model: 1995 GTR V-Spec R33
Circuit Name: Sandown
Lap time: 1:30
Modifications : 0.95bar, 4" exhaust, pod filters, pump & surge tank, fmic
Engine: stock
Power: 217awkws
Suspension: stock v-spec (hard!)
Tyres: 245/45 17 bridgestone S02
Brakes: R33 stock (brembos)
Body weight: stock
Car Make and Model: 1992 GTR R32
Lap time: 1:35
Modifications : 0.95bar, 4" exhaust, pod filters, pump & surge tank, fmic, unichip piggy back computer
Engine: stock
Power: 205awkws
Suspension: stock - oversteer city
Tyres: 245/45 17 cheapies
Brakes: stock (didn't cope well!)
Body weight: stock
Edited by captainah
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
