New PB for me at wakie
SAU Nickname: evil weevil
Car Make and Model: r33 gtst failboat
Circuit Name: wakefield
Lap time: 1.13.06 - w000t - just a bee's dick away from a 1.12!!!
Modifications
Engine: usual bolt ons with gtrs
Power: was about 230rwkw
Suspension: bilstein stuff
Tyres: old r888's
Brakes: dba
Body weight: standard plus a fat driver
  • 4 weeks later...
Hi Guys
Sorry not a Skyline
SAU Nickname: kingscorp
Car Make and Model: RX7 Series 6
Circuit Name: Barbagallo
Lap time: 61.4
Modifications
Engine: 13b Bridgeport Turbo
Power: 400 rwhp
Suspension: Bilstein
Tyres: 225/50/16 Bridgestone re55
Brakes: AP / Harrop calipers (Padgid Pads) Alcon Rotors
Body weight: 1200kg inc driver
I am building a Silvia s14a, so hopfully will have a lap time up soon.
Was great fun throwing a GTR around although my 'stocky' doesn't handle as well as a well sorted example. The well sorted Evo's and Rex's did well as expected but the difference was 2s between me and 1st place (sorted Evo 8 I think) so not huge.
See in car vids of my runs here:
http://www.skylinesaustralia.com/forums/Mo....html&st=40
Ahhh, whats a baseline time? I didn't have the stereo pumpin if that's what you mean? I'm putting the better time down to my running a massive hangover and 3 hours sleep, witness the Dutton Sandown effort for prior evidence of that :D, although, even though I was very "relaxed" in the car, I failed to stay absolutely flat out under Dunlop bridge :[
There's been no change to the car save for a tune which has made it a little more linear in it's power delivery, same old bald and blued Dunlop 02G's, no alignment or setup changes yet.
I can't wait to throw your green bits in it, but figured there wasn't much point rushing and changing it until I can directly compare it on the same track, which means either visiting Morgan Park for a weekend or waiting until Lakeside opens again.
Giant and I will give it a good alignment and corner wieght as soon as we both have time, and will likely setup your green hornets for installation at the same time. :(
SM Motorsport GTR
Driver: Sam Markov
Date: 24.10.2008
Winton lap time: 1.28.30 (max speed 215kph)
More to come as still unhappy with suspension and down about 30 rwkw
WOW, that's an awesome effort, that's flyyying...
What tyres were used?
That max speed is about 15km/hr up on what I can run there. Be good to know where that extra speed comes from - whether its corner exit speed, grunt, weight or a mixture of all of them.
I think its pretty safe to say its a mixture of them all, even though he was down 30rwkw at the time. If you really want to know, give him a call. I think it is also pretty safe to say that there is still quite a bit in it.....possibly another couple of seconds. Now I know some people may laugh at that, but they qoviosly dont know Sam. He was actually quite dissapointed with the car on the day.
So are you gonna tell us what tyres he used or is that a secret?
No secret............will be sure to post it up when i find out, other matters were more pressing at the time of conversation .
Regardless, all tyres he currently uses are capable of those times within a second or so of each other. There are quite a few more factors to take into account with this car that are a bigger contribution to those times.
Edited by G_T_R
I just came back from Winton today. After looking at the times you guys are posting for the long track I am going home with my tail between my legs. :yucky:
Gotta get me some slicks for my road car :P, and finish the track car ASAP
Edited by Tektrader69
New PB for me at Sandown today - 1.21.2
Was a the Holden Sporting Car Club / Ford Four Car Club Sprints
Alot of varying speeds in my group would be a large understatement.
A bit of battle scarring too. Another GT-R there caught fire unfortunately, no one injured more importantly.
Some footage
http://au.youtube.com/watch?v=0eDExeP6fC0 ----> First session, last flying lap was my PB
http://au.youtube.com/watch?v=wcIDKXJp5Yo -----> Second session - a spin and a DVD sized crease in the rear quater panel :down:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
