Top effort Dave!
You had some good weather today!
The car was mostly behaving itself unlike last time. Had to add a bit of rear toe to keep the arse end a bit more stable over the bumps/ripple strips and then it was surprisingly easy to keep ripping out low 1:22. Shame natsoft didn't work as it'd be nice to get some official confirmation of the time.
Yeah, it was great weather out there.
Lofty had the starlet out too. That thing is just awesome
Cant remember if Ive posted here.
Symmons Plains 62.3
Baskerville 61.00
R32 GTS
222kws
Modifications
Engine: FMIC, pod, 3 inch turbo back, R32 high flow turbo, jjr coils, 040 pump, 444 inj
Power: 222rwkw
Suspension: whiteline front bar, std rear bar, -3 F camber, -1.5 R camber, std shocks, kings lwd springs, strut bar
Tyres: RE55's on 7.5 inch rims
Brakes: dba 4000, bendix srt and race
removed most of interior (well, we have now jbr90.blogspot.com) only dashboard and seat left and roll cage of course
door windows to be replaced with plexiglass
no idea of weight, we remove some add some prob slight less than standard now considering the cage weighs 60kgs
removed fan blade, using thermo (keep fan blade close by... just incase!!)
hoping times will drop by close to a sec at both tracks
SAU Nickname: R32 Stuart
Car Make and Model: Gtr R32
Circuit Name: Wakefield Park Damp Dry Line
Lap time: 1.06.3 Dorian - State Round ( 28/06/09)
Modifications
Engine: Standard + N1 Turbo's, Injectors, Cam gears, Exhaust
Power: 310.6kws Thanks CRD Sydney
Suspension: HSD
Tyres: Dunlop DZ03's 255 (worn out)
Brakes: ECB Rotors and pad, Standard Calipers
Body weight: Full Trim - Rego'd
Edited by R32 Stuart
I got hello kitty out to OPGP today
SAU Nickname: badhairdave
Car Make and Model: S13 Silvia
Circuit Name: OPGP
Lap time: 1:22.00 (lap timer) natsoft is playing up and only has my first few laps of the day despite me seeing a printout of 1:27 after the second session?
Modifications
Engine: s14 SR20DE with 280 cams
Power: 110rwkw approx
Suspension: front S15 stock struts with camber tops and heavier springs, castor rods, rear old bilstein struts with heavier springs, nismo traction arms and LCA's, d project camber and toe arms.
Tyres: 235/45-17 r888 gg
Brakes: r34 gtt front with sbs carbon ceramic pads, rear s15 with cheap shit pads
Body weight: Around 1000
Wakefield Park
No changes to setup
rear tyres shot so had to be a little tentative in a few places
best of 1:09.87
natsoft
SAU Nickname: PaulBNR32
Car Make and Model: Nissan R32 GTR
Circuit Name: Winton
Lap time: 1:34.77
Modifications
Engine: forged pistons, ARP studs, cams
Power: 300 kw at all 4
Suspension: HKS
Tyres: 255 RE55
Brakes:
Body weight: 1650kg (full trim street car)
SAU Nickname: Blue32
Circuit Name: Mallala
Lap time: 1:15:03
Modifications
Engine: Forged
Power: estimated 360 rwkw (dyno'd at 400rwkw 1.5 bar, ran at 1.3 on the track)
Suspension: DMS
Tyres: 255 RE55
Brakes: AP CP5200 fronts / STD rear
Body weight: 1485kg (including driver)
Geez, ask me if I'm bloody happy today! Took 2.7 secs off my best Lakeside lap with just a new set of rubber and a little more midrange grunt from a better tune :)
SAU Nickname: Marlin
Car Make and Model: Nissan R32 GTS-t
Circuit Name: Lakeside
Lap time: 58.63
Modifications
Engine: Std
Power: 200RWKW
Suspension: Apexi N1
Tyres: 235/45/17 Dunlop O3G SR
Brakes: GTR Brembos, Ferodo 3000 pads
Body weight: 1285kg w/- half fuel
  • 3 weeks later...
Had the GT-R out at the Maserati Track day today at Sandown, 2nd time out since doing a heap of mods to the car, still getting used to it, but was happy to do a 1.21.3 before the engine cried enough!
SAU Nickname: Z1LLA
Car Make and Model: R32 GT-R
Circuit Name: Sandown
Lap time: 1.21.3
Modifications
Engine: Standard/unopened RB26
Power: 340rwkw
Suspension: Tein Coilovers, Whiteline swaybar - front only, adjustable upper arms - front
Tyres: Very worn/old RE55s 255/40/17
Brakes: R33 Brembos
Body weight: Standard GT-R weight
Thanks mate, bottom end we think probably due to starvation issues.
Saw an R33 GTS-T with SAU stickers but that was it.
Heap of quick GT-Rs out there including JFK, a white Racepace R33 I think along with a couple of targa style R32's and about 5 R35s! Was an awesome trackday in terms of the types of cars entered!
Mat,
you PM'd me about my car mods and I can't PM back because I haven't yet made 10 posts on the forum.
My car would be in the Modified class. I ran with RE55 tyres and I also have a Bosch fuel pump and adjustable reg.
Paul
Got a new time 1:43.1 :)
SAU Nickname: Codeblue
Car Make and Model: R33 Gts-t
Lap time: 1:45.5
Modifications:
Engine: Rb25det
Power: 200kw@ .8bar boost
Suspension: Bilstein, hicas lock, castor bushes
Tyres: Kumho xs
Brakes: standard size rda slotted dimpled rotors, braided lines, qfm k750 track day pads
Body weight: standard
Circuit Name: OPGP
Modifications
Second time out at OP GP, new engine and box, no other changes
Engine: s15 SR20DET with 3071
Power: 270rwkw @ 16psi (not running it at 285 until i get a better handle on the car)
new pb of 1:21.79 (bit slower than i would have liked considering the lack of opportunity to better it)
Need to relearn throttle control and get my corner speed back up to where it was with the NA.
Happy about the lack of major issues with the new setup
good work Dave.
Got to be pretty happy with the power too! I want! Is that S15 SR20DET standard internally? cams?
Thanks mate, though i think it's well below the potential of the thing
small duration reasonable lift cams and springs but otherwise stock
Oh and some good news: Looks like OP will be open for an extra month
Edited by badhairdave
  • 3 weeks later...
hahah sucked in I go to the top of the oran park short list just before they close the track....47sec flat this arvo :3some:
Thats pretty quick considering the conditions. Was this the Production car or the shoestring one?
ahh its ok it dried up in the arvo and this was the last session of the day. It was the production car + passenger seat in, but with 18psi (about 280kw). With standard boost 12psi best I could do was 48.5, so even on a tight track 50 extra killer wasps make a big difference.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
