Top effort Dave!
You had some good weather today!
The car was mostly behaving itself unlike last time. Had to add a bit of rear toe to keep the arse end a bit more stable over the bumps/ripple strips and then it was surprisingly easy to keep ripping out low 1:22. Shame natsoft didn't work as it'd be nice to get some official confirmation of the time.
Yeah, it was great weather out there.
Lofty had the starlet out too. That thing is just awesome
Cant remember if Ive posted here.
Symmons Plains 62.3
Baskerville 61.00
R32 GTS
222kws
Modifications
Engine: FMIC, pod, 3 inch turbo back, R32 high flow turbo, jjr coils, 040 pump, 444 inj
Power: 222rwkw
Suspension: whiteline front bar, std rear bar, -3 F camber, -1.5 R camber, std shocks, kings lwd springs, strut bar
Tyres: RE55's on 7.5 inch rims
Brakes: dba 4000, bendix srt and race
removed most of interior (well, we have now jbr90.blogspot.com) only dashboard and seat left and roll cage of course
door windows to be replaced with plexiglass
no idea of weight, we remove some add some prob slight less than standard now considering the cage weighs 60kgs
removed fan blade, using thermo (keep fan blade close by... just incase!!)
hoping times will drop by close to a sec at both tracks
SAU Nickname: R32 Stuart
Car Make and Model: Gtr R32
Circuit Name: Wakefield Park Damp Dry Line
Lap time: 1.06.3 Dorian - State Round ( 28/06/09)
Modifications
Engine: Standard + N1 Turbo's, Injectors, Cam gears, Exhaust
Power: 310.6kws Thanks CRD Sydney
Suspension: HSD
Tyres: Dunlop DZ03's 255 (worn out)
Brakes: ECB Rotors and pad, Standard Calipers
Body weight: Full Trim - Rego'd
Edited by R32 Stuart
I got hello kitty out to OPGP today
SAU Nickname: badhairdave
Car Make and Model: S13 Silvia
Circuit Name: OPGP
Lap time: 1:22.00 (lap timer) natsoft is playing up and only has my first few laps of the day despite me seeing a printout of 1:27 after the second session?
Modifications
Engine: s14 SR20DE with 280 cams
Power: 110rwkw approx
Suspension: front S15 stock struts with camber tops and heavier springs, castor rods, rear old bilstein struts with heavier springs, nismo traction arms and LCA's, d project camber and toe arms.
Tyres: 235/45-17 r888 gg
Brakes: r34 gtt front with sbs carbon ceramic pads, rear s15 with cheap shit pads
Body weight: Around 1000
Wakefield Park
No changes to setup
rear tyres shot so had to be a little tentative in a few places
best of 1:09.87
natsoft
SAU Nickname: PaulBNR32
Car Make and Model: Nissan R32 GTR
Circuit Name: Winton
Lap time: 1:34.77
Modifications
Engine: forged pistons, ARP studs, cams
Power: 300 kw at all 4
Suspension: HKS
Tyres: 255 RE55
Brakes:
Body weight: 1650kg (full trim street car)
SAU Nickname: Blue32
Circuit Name: Mallala
Lap time: 1:15:03
Modifications
Engine: Forged
Power: estimated 360 rwkw (dyno'd at 400rwkw 1.5 bar, ran at 1.3 on the track)
Suspension: DMS
Tyres: 255 RE55
Brakes: AP CP5200 fronts / STD rear
Body weight: 1485kg (including driver)
Geez, ask me if I'm bloody happy today! Took 2.7 secs off my best Lakeside lap with just a new set of rubber and a little more midrange grunt from a better tune :)
SAU Nickname: Marlin
Car Make and Model: Nissan R32 GTS-t
Circuit Name: Lakeside
Lap time: 58.63
Modifications
Engine: Std
Power: 200RWKW
Suspension: Apexi N1
Tyres: 235/45/17 Dunlop O3G SR
Brakes: GTR Brembos, Ferodo 3000 pads
Body weight: 1285kg w/- half fuel
  • 3 weeks later...
Had the GT-R out at the Maserati Track day today at Sandown, 2nd time out since doing a heap of mods to the car, still getting used to it, but was happy to do a 1.21.3 before the engine cried enough!
SAU Nickname: Z1LLA
Car Make and Model: R32 GT-R
Circuit Name: Sandown
Lap time: 1.21.3
Modifications
Engine: Standard/unopened RB26
Power: 340rwkw
Suspension: Tein Coilovers, Whiteline swaybar - front only, adjustable upper arms - front
Tyres: Very worn/old RE55s 255/40/17
Brakes: R33 Brembos
Body weight: Standard GT-R weight
Thanks mate, bottom end we think probably due to starvation issues.
Saw an R33 GTS-T with SAU stickers but that was it.
Heap of quick GT-Rs out there including JFK, a white Racepace R33 I think along with a couple of targa style R32's and about 5 R35s! Was an awesome trackday in terms of the types of cars entered!
Mat,
you PM'd me about my car mods and I can't PM back because I haven't yet made 10 posts on the forum.
My car would be in the Modified class. I ran with RE55 tyres and I also have a Bosch fuel pump and adjustable reg.
Paul
Got a new time 1:43.1 :)
SAU Nickname: Codeblue
Car Make and Model: R33 Gts-t
Lap time: 1:45.5
Modifications:
Engine: Rb25det
Power: 200kw@ .8bar boost
Suspension: Bilstein, hicas lock, castor bushes
Tyres: Kumho xs
Brakes: standard size rda slotted dimpled rotors, braided lines, qfm k750 track day pads
Body weight: standard
Circuit Name: OPGP
Modifications
Second time out at OP GP, new engine and box, no other changes
Engine: s15 SR20DET with 3071
Power: 270rwkw @ 16psi (not running it at 285 until i get a better handle on the car)
new pb of 1:21.79 (bit slower than i would have liked considering the lack of opportunity to better it)
Need to relearn throttle control and get my corner speed back up to where it was with the NA.
Happy about the lack of major issues with the new setup
good work Dave.
Got to be pretty happy with the power too! I want! Is that S15 SR20DET standard internally? cams?
Thanks mate, though i think it's well below the potential of the thing
small duration reasonable lift cams and springs but otherwise stock
Oh and some good news: Looks like OP will be open for an extra month
Edited by badhairdave
  • 3 weeks later...
hahah sucked in I go to the top of the oran park short list just before they close the track....47sec flat this arvo :3some:
Thats pretty quick considering the conditions. Was this the Production car or the shoestring one?
ahh its ok it dried up in the arvo and this was the last session of the day. It was the production car + passenger seat in, but with 18psi (about 280kw). With standard boost 12psi best I could do was 48.5, so even on a tight track 50 extra killer wasps make a big difference.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
