dont get me started on YJ's and performance China Racing wise lol. I think a few of you saw the shit storm on some of the products I and a few others had bought which do not fit.
FYP
  • Like 1
FYP
good call. fixed it myself too ;)
I HAVE to say; That certain supplier is worse than the producer, as they should have stopped importing certain parts. Anything to make a quick buck eh? Don't worry about stepping over anyone on your way there.
quick question ,what if you over tap the spark plug and the gaps to small. what do you use to widen the gap without damaging it ?
i have used a flat head in the past and was very careful to push it up.
I think you are aware of the problem (being the coils) and band aiding it by gapping the plugs down isn't really going to be a long term solution.
Our setups are quite similar. Same turbo, computer, AFM, injectors. Though my car makes around 40 rwkw more at the same boost.
I run Splitfires and only had an occasional misfire when using BCPR6ES plugs, but since changing to one heat range colder (the same as you are running) I've had no misfire issues.
I've got brand new Splitfires with BCPR7ES (I think, or whatever Trent told me to get). On 18psi I still had a misfire. Gapped them to about .6mm and they are all good.
I think you should be aware that results with coilpacks and plugs seem to vary quite greatly on RBs for some reason. Two people can have identical set ups but have two very different experiences. There's obviously something else in play, but plug gaps are the only known fix as far as I am aware.
before reading replies i figured out how to put the gap back up haha i found my round medallion tool and used that. i checked 2 spark plugs and the gap was 0.75mm ..they were supposed to be 0.9mm. unless im measuring it wrong but i span the medallion around carefully till it stopped moving and its where it landed.
i'll do the rest tomorrow so i can see what im doing lol
There's obviously something else in play, but plug gaps are the only known fix as far as I am aware.[/background]
Only known fix? There are several ways that could fix the problem other than gapping down the plugs.
It could be a poor engine or coilpack loom. Or the engine earth could be the problem. Also the connection to the spark plug within the coil pack and the coil pack plug itself could be the issue - though this is easily fixed by cleaning the coilpack and using dielectric grease.
By gapping the plugs down, you are trading off low throttle performance and economy, and the car will make more power through the rev range with the largest gap you can get away with running.
So yes everyone's engine is in different levels of condition, but I'd fix the underlying problem rather than living with gapped down plugs.
yeah im just gapping them down for a temporary fix, didnt realise you lose low throttle response though :( car is already poor on petrol lol lucky to get 300km out of a full a tank .
coilpack loom look looks like new from my untrained eyes.
coilpacks look very clean i took two of them off earlier, i didnt use dielectric grease though i'll lhave to look into that
I find they're ok on the dyno whilst I'm tuning, great for street use.. as soon as I hit the track and do a few laps.. bamm misfire city!
But at 0.5mm it's tits.. no misfires at all!!!
Interesting
My old splitfires died recently (this was not a gap issue, they were breaking down nearly on idle. Must have had at least 1 no good coil) so i have a brand new set in now
Might gap the plugs a bit lower next time to be safe. Although its only a street car and havent really had any dramas before on 0.8
Interesting
How long did they last if you don't mind me asking?
update on the ebay dude:If it is a faulty coil then it would only be 1. It wouldn't be all 6 at the same time.
This alone is an extremely rare occurrence as a lot of care goes into these coils during the manufacturing process.
We will need isolate the single faulty coil though so it can be replaced under warranty.
Thanks.
whats my reply going to be ? should i go for replacements or keep insisting on a refund. to me replacing them is more hassle and seems a waste of time if they're going to keep failing
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
