Day/Date:- Sat 21st May 2016
Time:- 1pm until 4pm approx
Address:- 51 Forge St Blacktown
Hosts: Garry and Jack of Top Secret Imports
Offer #1:- Free BBQ and Drinks
Offer #2:- Tech Talk about
* Inspection of your prospective import
* Bidding process
* Importing
* Compliancing
* Exporting (- now this is new)
Open to SAUers and Friends although this is not an official SAU.NSW event
Only register your interest if it's genuine - for more accurate catering estimates please!
Other Car Clubs on Fb will get the same offer.
It'll be an interesting afternoon with Q&A
The President of SAU.NSW might also wish to make an announcement Re upcoming events.
  • 1 month later...
  • 5 weeks later...
  • 5 weeks later...
:action-smiley-069: Guest Speaker at this Event will be Kristian Appelt, who is flying up from South Aust for us.
* Iron Chef has of course brought in some of our cars
* Iron Block is his name in the USA
* Iron Lady is his name in the UK
We are privileged to have him with us at Blacktown this Saturday.
Ask him anything you like during Q&A.
