Hi all
I have the following parts from a S15 track car I was building, however life has gotten in the way and I'm parting out my track car build as it has been collecting dust.
1. S15 shell. Non rolling, non registerable. Straight shell.
Stripped of interior and all glass except windscreen. Still has dash, steering wheel and all loom/electrics. Will not come with exterior panels. Engine bay is bare.
$1200
2. Rebuilt Front and Rear R33 GTR Brembo callipers with brand new front Slotted and Dimpled RDA rotors, standard rear rotors, standard pads.
All 4 callipers were rebuilt prior to callipers being placed in storage. Caliber paint condition is good.
$2100
3. Racetech RT4000W Seat. Good condition.
$800
4. Set (4) of Toyo R888 285/35R18. Brand new, half a track day old. Engine blew through second session. They have been stored indoors wrapped in plastic.
$750
5. Race Technology Dash2 dash. Intended to be used to monitor and log engine vitals, however project is no longer going ahead.
$550.
6. Set of Project Mu HC+ brake pads to suit Brembo R32 V-Spec I & II, R33 GTR (all models) and R34 GTR (all models). Brand new, still in plastic in box.
$400
7. S15 Reo bar.
$370
8. S15 left and right doors. Complete with electrics, windows and door cards.
$350/pair
9. S15 left and right front quarter panels.
$300/pair.
10. Takata 5 point harness. EXP 2010. Good condition.
$50
More parts to come as they are removed from the car.
PM me
Cheers
Joseph
if the takata harness is genuine/real i will take it!
pm me your number please
Can't PM you, inbox maybe full?
Might be interested in the Dash, can you tell me more about it? Any photos? What sort of logging capacity does it have? Does it connect to a Haltech easily enough?
Takata harness sold.
Race Technology Dash2 and S15 Guards sold pending payment.
Sorry mate, only what's listed.
Front guards sold, dash2 sold.
Location?
Doncaster, Vic.
Replying to your PM now
Is the dash sold? Let me know if it falls through
Dash has sold
  • 1 month later...
  • 1 month later...
Hi, Do you have the S15 ( turbo manaul ECU loom with injector and coil pack loom ) I am chasing one for my S15 ( red top SR20) track car
Please call Alex 0433878905 Braeside 3195, can pick up from Donscaster
cheers
Anyone has got one for sale?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
