If NSW, something <15mm difference in diameter from the stock R32 tyres, which are 225/50/16 = 631.4mm diam. 245/35/18 and 255/35/18 look ok, but the standard R34 tyre size (245/40/18) is too big - its 20.9mm different at 653.2mm diam.
https://www.sau.com.au/forums/topic/462587-r34-gtr-rims/#findComment-7674973
I've been through a few RBTs and even pulled over on the freeway in ACT for a drug test. The police never commented on my ride height (was a bit too low before for my liking), my wheels nor my exhaust.
Went from BNR34 wheels to LMGT1s, ran minimum 265/35/18 tyres. Of course, my car looks fairly standard and not some drifter/stancenation.
https://www.sau.com.au/forums/topic/462587-r34-gtr-rims/#findComment-7677525
265 tyres on those wheels won't be an issue and no need to run extra camber to makes them clear either
I run a 265 on a 18x9.5 +22 on mine and I have the wheels sitting very up right and they don't scrub at all, I also haven't rolled the lips on the guards either
  • Like 1
https://www.sau.com.au/forums/topic/462587-r34-gtr-rims/#findComment-7682946
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
