I have an upper cracked radiator for an NM 35 axis au tech 2002 model.
Just below fuel cap neck on the right hand side. Perhaps 7cm from neck
Replacement will cost $1100 with labor. is that a reasonable price .
What choices do I have with radiator.
Repair iis not an option I was told
I can't do this myself.
With no coolant touching the sensor the temperature gauge was reading near normal.
I thus thought the car was operating normally every time I glanced at the gauges.
I was thinking of buying an oil temperature
or oil pressure gauge so I can get better engine information .
Is that over kill.is there a preferred choice amongst you guys.
If I am going to get another gauge what other gauges might be an option.
Is the such an animal out there as an oil temperature pressure gauge.
Can't see any online. What's the best brand please?
What are your thoughts
What will my 2002 model allow me to do in terms of oil
gauge dashboard placement.
Hoping for a quick reply to sort out my options
Also where do you suggest this gauge goes ?
I don't want to rip out
my satnav DVD player nor the TV screen .
Would prefer to have near other gauges but assume because of cost
I will have to pay for it to be installed near the driverwindscreen Pillar.
If there's was no coolant how long could I drive for without doing some damage ,
assuming engine was cold.
Assuming car was warm
How do I know I already know I have not done damage .as far as I can tell
Engine is okay
Thanks in advance for any thoughts
This leak continued for at least two days of driving unnoticed
but I don't know where the level was during those two days or more
Do sensors have to be reset or air removed from system.
What happens if coolant is just added to a new radiator replacement.
How can I tell if the job has been done properly
apart from the fact that there would be no leaks
I would sugest that an alloy radiator would be the way to go I have replaced all the Stageas and the 32 with alloy. $300 each. Try Just Jap..
Who told you that it was unrepairable - a mechanical workshop or a radiator repair shop? Find another radiator repair shop for an opinion. I have had new tops put on my radiator for a lot less than the price of a new radiator and I have also bought new OEM radiators which have been fine and not unduly expensive (around $300). If yours is original it is 14 years old. Personally I would buy a new stock radiator from a radiator speialist.
A radiator shop will replace the anti freeze/conditioner and bleed the system.
Gauges are great but if they are going to cost you an arm and a leg just check your water and oil levels once a week.
Top tank not repairable as was told made of plastic.
I assume true...is it true... according to midas muffler.
Top tank is not repairable but can be replaced. Would you take your computer to a carpenter? Go to a radiator specialist.
  • Like 1
A new top tank for an NM35 is worth as much as a new radiator; buy the one that Lakes101 and move on with your life.
It's larger, and better suited to our conditions than the undersized stocker; your car will thank you.
I have fitted about 6 in the last few weeks, pretty common. Some brands require a fair bit of cutting so beware.
Alloy ones can have their own issues, probably due to the Chinese quality control. I prefer the plastic tank M35 specific ones these days.
I used the radiator Scotty was just mentioning. Fitted it last weekend.
It's at least twice the thickness as the standard and didn't require any modifications at all.
Took maybe an. Hour to do the swap, not a hard job on the m35 at all. But bleeding the cooling system is another problem all together.
Definitely look into the "coolant bypass mod" on these forums.
I also just did this on the weekend along with a new thermostat.
Took very little time to bleed and the car now sits lower on the temperature gauge.
Edited by Bmx537
Had no choice but to send to Midas, locally as Nissan Indooroopilly and Nissan Moorooka refused to accept my towed vehicle being a personal import !!!!!
I will remember that .
Definitely not happy with price gouging at midas but car not driveable thanks for the info so far
What do you mean you had no choice? I see there are many radiator repair shops in Brisbane such as
http://www.reddevilradiators.com.au/index.php/radiators
V35 350gt G35 look to be similar but are 26mm rather than 16mm
Wider by an inch or two, meaning there is a substantial amount of cutting for the shroud and fiberglass front.
I found that to be the case with C34s.After fitting an FMIC and FFP, I somehow fitted a 26mm plastic rad instead of the 32mm. My fault it was early days with the Stags and never noticed it. I had overheating problems. The stock water temp gauge never went over halfway, but when coming up the mountain the oil temp gauge I fitted went up to 120/130.+.And it started to boil in the back of the plenum.
Once I fitted the 50mm alloy, no more boiling and oil temp always less than 100.
Had to do a bit of cutting but well worth it.
Edited by 66yostagea
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
