Hey guys
How do i fix the rear camber and raise the ride height? As you can see with the setup i have now the tires dont fit the rims because the car is lowered too much and there is some camber. The front tires are the same but with coilovers so i think i can fix them up its just the back ones that are the problem.
Any advice would be most appreciated thanks.
...........wut
the tires dont fit the rims because the car is lowered?
what are you trying to fix? do you want negative camber to fit wide wheels under a low car?
camber is the only thing squeezing the wheels (which are either too wide or the wrong offset however you look at it, you aint fixing that without new wheels) under the car.
raising it will reduce some natural camber but then your wheels are going to poke out more.
do do you want to raise the car and remove the negative camber?
that pick tells us nothing, also what is your current setup? wheels specs, what has been changed?
what suspension components are you using? do you have adjustable things like coilovers or adjustable camber arms ect.
Edited by GH05T
i want to fix the camber and be able to fit tyres onto the rims without having them stretched. The tyres that are on the wheels atm are stretched. The front has coilovers not sure about the back. I dont have adjustable camber arms but im looking into buying some for the back. Im not sure what the wheel specs are. Basically what i want to know is what do i need to fix the rear camber and how to fit the tyres properly.
Sell wheels and buy wheels that fit within the guards.
Get adjustable upper arms to adjust camber. You may get away with adjustable bushes (e.g. Whiteline).
You may have to get new suspension (or second hand rear struts, but who know what will happen to your handling).
take the wheels off and see whats been installed, if you have excessive negative camber it may have aftermarket camber arms already, i cant see from that pick but it may be from being too low.
and are you saying its got coilovers in the front but nor rear and is low all round? thats a bad combo.
nothing is going to make those wheels fit though, bigger tires (which may be more suited to the wheels) are never going to fit the car, you can bandaid an offset too high but not too low, those wheels do not fit period.
do this:
- new wheels that fit the car.
- "if" the aftermarket suspension is adjustable raise it back up or,
- get coilovers, stock structs or new suspension to suit the height you want and get the car to the required height (good move)
- IF the camber is still too negative get new camber arms to suit (probably stock)
Edited by GH05T
Thanks for the advice guys. A shame nothing can be done for the wheels i have now though. I thought i could put coilovers on the back and raise the height so that bigger tyres can fit the rims.
Well you could do as you say. Raise the height so the tyres don't foul the guards at rest then fit tbigger tyres. But just as the boys said above, they will now poke put even more, especially if you also wind off some camber. And they will probably still foul the guards on bump.
Yeah you have the wrong wheels - sell them and get something with a sensible offset. There's no other solution. As an added bonus you wont have to worry about getting defected any time a cop pulls you over. :yes:
If you want to keep the current wheels, you can look at wider guards or rolling the guards.
Have a look in there in case if PO has installed spacers.
Fixing camber at that height will bring the top edge of the tyre closer to the wheel arch.
Adjustable lower and upper arms can help you bring in the wheels a little if they dont rub on the inside.
The CV joints can slide in more if needed, but dont go too far.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
