Located VIC 3978.
$9500. Price negotiable.
Selling due to need for 4x4 for work related reasons and to be completely honest, all the car needs is a financially stable owner. Due to a string of bad luck I've been unable to maintain employment for more than ~ 4 months at a time since purchasing the vehicle.
More pics @ instagram.com/cevlol
1993 Series 2 GTS4 sedan, white.
Engine:
152xxx K's (speedo swapped out, original one f**ked).
Fairly stock RB20DET
Turbosmart boost controller.
Remapped stock ECU.
42mm Alloy Radiator.
Custom FMIC w/ Ford core, shorter piping, more spool w/ brand new Proflow joiners + brand new hose clamps. No BOV, can plumb one in with silicone T piece for RWC.
New water pump less than 7k's old.
Full 3" turbo back w/ 3" dump/front pipe, stainless steel exhaust w/ high-flow cat & rear oval muffler. Note is 1hunnid.
Brand new genuine Nissan oil filter, less than 1000k's ago.
Brand new Motul Chrono Ether 300V 10W40 motor oil, doesn't need to be replaced for 9,000k's.
Brand new BCPR6ES plugs, less than 1000k's ago.
Interior:
Brand new R34 V-Spec Aluminium Pedal set.
Brand new Superior Auto Creative Carbon shift & handbrake boots.
Brand new Nissan shift knob.
Factory Series 2 GTST/GTS4 seats in very good condition.
Factory GTST/GTS4 steering wheel.
Exterior:
Brand new R32 GTR N1 front bar w/ eBay FRP vents.
Brand new R32 GTR N1 front reo.
Brand new Bosch Aerotwin Flat Wiper Blades.
VGC genuine R32 GTR front lip, could use respray but otherwise perfect cond.
Average condition R32 GTR wing FRP, minor hole one side.
Driveline:
R32 GTR rear shocks.
R32 GTS4 factory shocks.
HICAS lock bar / eliminator kit.
NISMO strut brace.
Brand new Exedy HD Organic clutch, freshly machined stock flywheel, less than 1000k's old. Penrite full synth in box atm.
ATF in transfer case/ATTESSA.
Custom 4WD/RWD toggle switch for sliding fun, don't use it often to be honest. Car stays in 4WD most of time.
Brand new Nismo R32 GTR slave cylinder.
Brand new HFM R32 master cylinder.
40% RWC tyres on R33 stockies.
Misc:
$1000 alarm system. Remote central locking, immobilizer + alarm.
Receipts from myself + last two owners.
High level brake light fitted to clear RWC fault as GTR wing is aftermarket.
Headlight loom completely rewired, no f**k arounds. H1/H3 combo w/ T10 parkers.
$3000 worth of sound gear, including Dynamat throughout. Can remove/include for adaptive pricing.
Bad:
Needs respray imho. White is 326 Crystal White but rough on quarter panels (in touch up paint atm, still very nice looking). Bonnet clear is well, peeling.
2nd gear very minor crunch. Could benefit from Redline treatment.
Input shaft bearing noise when clutch not pressed, goes away after 5 min drive. Very common issue that does not affect performance.
Reply here and/or email: [email protected]
Mobile outta order atm, changing carrier.
No swaps, unless you have a dope D22 Nav w/ 150k's or less (friend's selling me his for $9k).
Edited by Cev
  • Like 1
Price drop $7,500! 100% my loss ... brand new clutch, 300V & most of interior :)
I start my new job as a residential builder on 15th! Need this gone so I can pick up my Nav aka. work ute!
Cheers,
Cev
Bump, comp test done today. 150 across all 6 cyl ~ 5-8%
Call 0421 559 655 to express interest.
Bump n' stuff.
Still available, $6,500.
Will only need passenger side CV boot clamp for RWC.
Call 0421 559 655 ~
Cheers,
Joe
Edited by Cev
Bump.
$6,000 this week, without sound system.
Replaced broken coilpack clip with brand new replacement.
Will need passenger side CV boot clamp for RWC & potentially BOV.
Call 0421 559 655 ~
Bump.
Still up for grabs, $6,000 cash.
Car needs following for Roadworthy Certificate;
- front passenger CV boot clamp/grease, CV boot is fine, no tears -- $30
- BoV plumbed into current FMIC piping using Silicone T piece -- $80
- *potentially* may need stock intercooler if RWC inspector fails current custom setup -- $100 max (I can lend you a stock intercooler for RWC).
Call 0421 559 655 !!
Need this gone THIS WEEK so I can grab a Navara I've been after for work!!
  • 4 weeks later...
$4500 and ill pickup wednesday
No longer for sale, unless you're willing to pay $11k with Reg/RWC, gearbox reco'd, and R33 GTR wheels.
ie it's now my daily because low ballers and down syndrome's made me keep it!
  • Like 1
  • 4 weeks later...
Bump, back up for sale. $7000 ono.
-Club Reg-able in 2018. Will still be clean asf, rustless shell if you maintain it.
-HKS return flow intercooler added to car, custom FMIC setup removed. A/C can be refitted. (photo below is the HKS FMIC, NOT my car in photo).
-Redline Shockproof Lightweight gear oil has been added to remove second gear slight crunch, worked flawlessly.
-Brand new Osram Nightbreaker Ulimited H1/H4 low/hi beam added w/ Phillips 4300k parkers.
Call 0421 559 655 with offers/interest. Don't lowball, I'll hang up on yo ass and pretend I have bad reception.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
