Located VIC 3978.
$9500. Price negotiable.
Selling due to need for 4x4 for work related reasons and to be completely honest, all the car needs is a financially stable owner. Due to a string of bad luck I've been unable to maintain employment for more than ~ 4 months at a time since purchasing the vehicle.
More pics @ instagram.com/cevlol
1993 Series 2 GTS4 sedan, white.
Engine:
152xxx K's (speedo swapped out, original one f**ked).
Fairly stock RB20DET
Turbosmart boost controller.
Remapped stock ECU.
42mm Alloy Radiator.
Custom FMIC w/ Ford core, shorter piping, more spool w/ brand new Proflow joiners + brand new hose clamps. No BOV, can plumb one in with silicone T piece for RWC.
New water pump less than 7k's old.
Full 3" turbo back w/ 3" dump/front pipe, stainless steel exhaust w/ high-flow cat & rear oval muffler. Note is 1hunnid.
Brand new genuine Nissan oil filter, less than 1000k's ago.
Brand new Motul Chrono Ether 300V 10W40 motor oil, doesn't need to be replaced for 9,000k's.
Brand new BCPR6ES plugs, less than 1000k's ago.
Interior:
Brand new R34 V-Spec Aluminium Pedal set.
Brand new Superior Auto Creative Carbon shift & handbrake boots.
Brand new Nissan shift knob.
Factory Series 2 GTST/GTS4 seats in very good condition.
Factory GTST/GTS4 steering wheel.
Exterior:
Brand new R32 GTR N1 front bar w/ eBay FRP vents.
Brand new R32 GTR N1 front reo.
Brand new Bosch Aerotwin Flat Wiper Blades.
VGC genuine R32 GTR front lip, could use respray but otherwise perfect cond.
Average condition R32 GTR wing FRP, minor hole one side.
Driveline:
R32 GTR rear shocks.
R32 GTS4 factory shocks.
HICAS lock bar / eliminator kit.
NISMO strut brace.
Brand new Exedy HD Organic clutch, freshly machined stock flywheel, less than 1000k's old. Penrite full synth in box atm.
ATF in transfer case/ATTESSA.
Custom 4WD/RWD toggle switch for sliding fun, don't use it often to be honest. Car stays in 4WD most of time.
Brand new Nismo R32 GTR slave cylinder.
Brand new HFM R32 master cylinder.
40% RWC tyres on R33 stockies.
Misc:
$1000 alarm system. Remote central locking, immobilizer + alarm.
Receipts from myself + last two owners.
High level brake light fitted to clear RWC fault as GTR wing is aftermarket.
Headlight loom completely rewired, no f**k arounds. H1/H3 combo w/ T10 parkers.
$3000 worth of sound gear, including Dynamat throughout. Can remove/include for adaptive pricing.
Bad:
Needs respray imho. White is 326 Crystal White but rough on quarter panels (in touch up paint atm, still very nice looking). Bonnet clear is well, peeling.
2nd gear very minor crunch. Could benefit from Redline treatment.
Input shaft bearing noise when clutch not pressed, goes away after 5 min drive. Very common issue that does not affect performance.
Reply here and/or email: [email protected]
Mobile outta order atm, changing carrier.
No swaps, unless you have a dope D22 Nav w/ 150k's or less (friend's selling me his for $9k).
Edited by Cev
  • Like 1
Price drop $7,500! 100% my loss ... brand new clutch, 300V & most of interior :)
I start my new job as a residential builder on 15th! Need this gone so I can pick up my Nav aka. work ute!
Cheers,
Cev
Bump, comp test done today. 150 across all 6 cyl ~ 5-8%
Call 0421 559 655 to express interest.
Bump n' stuff.
Still available, $6,500.
Will only need passenger side CV boot clamp for RWC.
Call 0421 559 655 ~
Cheers,
Joe
Edited by Cev
Bump.
$6,000 this week, without sound system.
Replaced broken coilpack clip with brand new replacement.
Will need passenger side CV boot clamp for RWC & potentially BOV.
Call 0421 559 655 ~
Bump.
Still up for grabs, $6,000 cash.
Car needs following for Roadworthy Certificate;
- front passenger CV boot clamp/grease, CV boot is fine, no tears -- $30
- BoV plumbed into current FMIC piping using Silicone T piece -- $80
- *potentially* may need stock intercooler if RWC inspector fails current custom setup -- $100 max (I can lend you a stock intercooler for RWC).
Call 0421 559 655 !!
Need this gone THIS WEEK so I can grab a Navara I've been after for work!!
  • 4 weeks later...
$4500 and ill pickup wednesday
No longer for sale, unless you're willing to pay $11k with Reg/RWC, gearbox reco'd, and R33 GTR wheels.
ie it's now my daily because low ballers and down syndrome's made me keep it!
  • Like 1
  • 4 weeks later...
Bump, back up for sale. $7000 ono.
-Club Reg-able in 2018. Will still be clean asf, rustless shell if you maintain it.
-HKS return flow intercooler added to car, custom FMIC setup removed. A/C can be refitted. (photo below is the HKS FMIC, NOT my car in photo).
-Redline Shockproof Lightweight gear oil has been added to remove second gear slight crunch, worked flawlessly.
-Brand new Osram Nightbreaker Ulimited H1/H4 low/hi beam added w/ Phillips 4300k parkers.
Call 0421 559 655 with offers/interest. Don't lowball, I'll hang up on yo ass and pretend I have bad reception.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
