Hi Guys,
I wanted to share this thread on here even though the badges in the images are Holden and Ford, we are currently manufacturing some others and hopefully get some pics up for you.
Working with 5 axis CNC Mill full 3d type badges or many things
Below are 2 images of some recent ones
Ford badge the customer wanted the parallel tool path lines across the bottom face, then we had the trace tool path around the inside edge to give it a diamond swirl look when polished. Outer edge smooth finish.
Second badge is for a friend's Green VL Commodore LS1 Burnout car - entered in the 2016 Summernats - Car name GUNJA - will also be at UBC Ballarat this weekend. In this image we have shown the same as first - 3D drawing to cutting then complete product, we cut 2 - 1 for each side of the vehicle and have shown before polish mill finished and semi polish - just waiting for more cut compound to arrive.
Anything you can think of with a badge we can pretty much incorporate into the design. Limited by imagination
Custom badges for tuned specific vehicles - Cutting this badge next and will post the detail of the Turbo when completed
We have another badge that is almost complete on the design - but I cant post it on here yet, the idea is Holden Ring with Lion Head only, Blown V8, Vehicle Name - for a Meth Blown Burnout Car, summernats entrant this year, it looks pretty amazing
Even fully polished or flat type resin filled - with full clear resin or even some candy color in resin to make the badge have depth and pop
Send us your idea's and we can fab something - once you are happy with the draft and approve for cut we can get it done reasonably fast. Obviously design and setup is the time consuming part but once the material is set cut time is usually quick for small jobs.
We are also cutting 3d designs into alloy rocker covers
If there is something you need manufactured in Billet,Plastic,Nylon,Brass,Alloy send us a message with the part needed and we will advise best alternative.
If you have the 3d drawing or 2d Cad drawing even better - if you only have a drawing on Paint or even a piece of paper with pencil dimensions we can CAD it then CAM it for you.
If any of you can assist with other forums that this can be posted on let me know - it would be much appreciated if you could share this link with friends and on forums for us, we can look after you with costing for those who help share this.
Tig Welding also in house
Cheers all
Custom RB26 ornament badges too then, I'm guessing? If so I'm very interested! :)
Yeah we can do the RB26 ornament with any design you like, Backing will have 3m VHB high bond Double Sided Tape
if you PM your sketch, design, idea, image, text etc - I can put together some designs for you to look at,
Material Preference: Aluminium, Carbon Fibre etc
Finish Type: Machine, Flat, Polished or Painted in any color code provided.
Color Inlay: Whether you want resin color in certain area's - Color Choice
Cheers
Small versions of the GTR boot badge to replace the GT badges that go on the guards would be good
Thanks for your input - I actually have the GTR Badge we are inlaying with different metal flakes in the lettering - with an embossed outer edge and resin filled. Will post some up when we get the chance.
As for the size thats not an issue at all - we can machine these to what ever size required - and the GT badges would look great changed to a smaller GT R type
Edited by tuning_vs_hardware
  • Like 1
Also interested in cost to make them up
We custom cut many items for customers ranging from anywhere from $60.00 and up for small badges would be at the lower end of the scale
Its hard to cost up an individual item to give you a cost as each item is different
Depending on the quantity and detail also has an impact in the cost
Just to give you an idea of the time spent and process
1. We draft the 3D Drawing or work with a drawing provided and turn it into a cut design
2. Material Size and Thickness
3. Work on tool path for cutting
4. We use anything from a 0.3mm to large cutting bits depending on detail needed
5. Some tool paths can be from 1 hours cutting to 30 hours cutting time
6. From memory the longest part we have done was 32 hours 28 minutes - with 11 operations and 7 tool changes
7. Setup of the material - running costs
8. Labor
9. Machining time and Distance - Tool wear
10. What finish the customer wants - Mill finish, Polished, Carbon Fibre with Polished Inserts etc
11. Packaging and Delivery
But just to run off a few of the processes we try to give the best price - its pretty amazing when you hear back from our customers when they received there own designed custom piece
Another example we cut some RB26 Ornaments with very low detail and they were about $69 each and another customer wanted some cut with pretty unique detail incorporated and they were roughly $125.00 each
If you send me what design or part you are looking at getting done - then I can work with you to design and provide the cost. Once the design is done it provides us with the time involved - we do not charge full setup costs as most of the work is in the designing - the design work is just a very small percentage of the total cost - just an example we are working on a job currently and the design was very involved with the file that the customer provided - to get the image to a 3D Cut drawing involved 18 hours of work and this would not be charged to the customer - so we try to work with you for cost
Hope this helps all - but we don't put exact cost for a certain piece on here - if you want custom pieces done send me your idea's - we will work with you and provide a cost in PM
this^^
Hi Anthony, I am also currently working on this design when I seen Chris post - I brought up the drawing last night and worked on the sizing for the GTR Badge for the guards.
I am also currently in the process of full respray on my 33 and took these badges off 2 days ago.
I will get a sample cut and post and see what time it takes - I wouldn't see it being a long process - Im looking to Metal Flake and Resin Fill the Badge
Should look pretty cool - with the 375 Micron DNA Red Flakes in where the R is on the Badge with the rest fully polished
When the samples done and I choose to run some extra's I will let you guys know so we can just run off 6 or 10 in one go.
Depends on Time and Finish whether it be Mill, Polished or Resin filled and polished could be from $25 to $70 per pair
I am also looking to redesign the Boot Lock Flip Cap with some custom work incorporated
After drafting the 3D Badge in 2 sizes for the Guards and Boot - we have some finish options we are looking at with various metal flake - encapsulated in clear resin
After we have the samples I will post some pics
See below design work on some color options
Let me know if your interested
I'd love a copy of the stock badge, no glitter, but tiny!
^^what he said^^
We have some pieces coming off the Mill tonight and tomorrow I will load the sample for the small GTR Guard Badge - let me know the dimension currently the size I am going to work with is 54mm x 44mm after doing a quick measurement on the Stock 33 GT Badge
Cheers guys will keep you informed
this^^
^^what he said^^
Hi All,
We had a sample cnc'd on the mill today - thought I would share the images of the mill finish
This badge dimension is designed to replace the Stock GT Badges on the front guards/fenders
I will also have the faces and contours polished to also provide you with the full polished finish.
Images only show as mill finish
And also no red inlay in the R - we will fill the R in Red after the polish.
These badges will also have VHB Double Sided Tape when completed
  • Like 3
GTR - Small Custom CNC'd Billet Guard Badges have been filled with DNA Blood Red Candy - Diamond Clear Over the top
below image is only a sample requested from some SAU members - also the white light reflection affects the full polish look - the finish is like chrome
If anyone would like black inlay on the very base part of the badge - where the GT and around the edge of the R on the very lower base part - we can also do this
Anyone interested send a PM and I will advise delivery details, costing, etc
  • 2 x Guard Badges
  • Fully Polished
  • Red Inlay
  • VHB Double Sided Tape
Thanks
  • Like 4
Hi all,
Just wanted to update this thread with some recent work for Dahtone Racing in Sydney - currently working on some finish options for this piece after they received their mill finish sample.
After working very close on the design with the customer and seeing it come to life looks great
Custom RB26 Engine Ornament plate
Looks pretty unique on their RB26 engine
https://www.facebook.com/165500486810662/photos/a.328775397149836.93556.165500486810662/1229243663769667/?type=3&theater
Hi All,
Updating post with recent inquiries in PM with the GTR R35 Badges drawing has been completed and now ready for cutting
Custom Machined CNC Billet - R35 GTR Guard badges to replace R33 or R34 GT Style - or what ever size you require can make these with any dimension required
Anyone interested send a PM and will advise details
Cheers
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
