I found 11mm from the bottom of the bootlid
and 25mm to the bottom corner of the R to the edge of the bootlid
and 30mm to the top corner of the T to the edge of the bootlid
The vspec/vspec II stickers sit vertically within the right, right side tail light (the bigger one, if u drew imaginary lines straigt down) a little closer to the right side
  • Like 2
So what I did with the V-Spec sticker was it came with a marking arrow, and I lined that up to the center of the bigger tail light. I hope this is the correct way.
Forigive my shitty paint skills but this will explain what i mean a bit better
you might have to save this image and zoom right in to see it better
I think I get what you mean with the GT-R Badge. Will work on that next.
  • 1 month later...
I've found the factory brochure photos which show the V-Spec and V-Spec II decal locations. Looks like they should be sit fairly central within the right, right side larger tail light as mentioned above however the V-Spec decal marking arrow appears to line up to the centre of the larger right taillight and the V-Spec II decal marking arrow appears to line up to the right hand edge of the inner circle of the larger right taillight. So that said you shouldn't line up the V-Spec II marking arrow centrally with the taillight as it will make the decal sit too far to the left, I've seen a few photos on google where it looks like this is what people have incorrectly done. Check out my attached photos which probably show it better.
  • Like 1
A lot of genuine Toyota badges come with an alignment cut out.
Looking at the photos that dark-knight uploaded, it looks like theres also an alignment arrow.
Someone with more knowledge may be able to confirm this.
Yes both the V-Spec and V-Spec II decals have alignment arrows (I called them marking arrows in my above post). The yellow line in each of the photos is where I believe the arrow should line up with.
Also worth noting there is an upper and lower "ridge" on the rear bar, the decal should be positioned evenly between these two "ridges" as shown in attached photo.
Edited by dark-knight
  • 1 month later...
Sorry to hijack this thread - but how do you guys feel about putting a R34 GTR badge on a R33 GTR? My R33 GTR badge got damaged recently so wouldn't mind trying something new.
Pro:-
* It's a more modern look of sorts
* It'll stand out more
Con:-
* GT-R owners will know
* Some GT-R owners will shake their heads
* A keen buyer might think that the rear has been damaged at some point in time
Thanks
Pro:-
Con:-
Thanks mate - well, I decided to go ahead with it anyway and the badge is on there...looks very nice in my opinion but I noticed 2 things about it...
1) the r34 GTR badge is a little smaller that the R33 one
2) The red painted area is more dark and bloodish red so looks a bit different
Therefore to make the badge look more proportional on what is a slightly bigger bootlid area on my R33 I had to move it up a bit from the bottom and slightly more towards the left but looks good in my opinion so no no worries there...I suppose it's still putting a GTR badge on a GTR so I won't be hung for treason! lol also, they look quite similar anyway
  • Like 1
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
