IBoughtANissan Posted February 19, 2016 Share Posted February 19, 2016 I've got a 98' Series 2 Stagea and the 4wd doesn't work (See more here: http://www.sau.com.au/forums/topic/463038-help-with-fault-finding-attesa-system-attesa-ecu-c34/#entry7685341)Just wondering how do i retrieve error codes relating to the 4wd system? I've got to the ABS/ESP computer (Also 4wd?) and a few forum posts reference a red flashing light through a hole or someone said it is on the PCB itself. I've pulled the cover off the computer and could not see a light anywhere (See photos attached).Is there another way to get the codes? Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/ Share on other sites More sharing options...
Duncan Posted February 19, 2016 Share Posted February 19, 2016 do you have access to a consult? It will report the error. Where are you located (not recorded on your profile) Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7686077 Share on other sites More sharing options...
IBoughtANissan Posted February 19, 2016 Author Share Posted February 19, 2016 Asked a mate today who said he might have one. If I shorted out the two pins and got 5 slow, 5 fast (No fault?), Will the consult pickup on the 4wd light error?I'm from Gosford,NSW (1 hour north of Sydney) Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7686083 Share on other sites More sharing options...
Duncan Posted February 19, 2016 Share Posted February 19, 2016 sorry my japanese is too poor (ie non existant) to tell if 5 slow 5 fast means no error. maybe someone else can help. Page C-32 in the stagea manual Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7686099 Share on other sites More sharing options...
IBoughtANissan Posted February 21, 2016 Author Share Posted February 21, 2016 My understanding of that list is that it's saying the 4wd light wouldn't be illuminated for error 55 on that list? Also that list corresponds to the led flashing light on the Attesa ecu in the boot (which mine does not have a flashing led)?Is there another list hidden away somewhere that corresponds to the consult port fault codes? Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7686723 Share on other sites More sharing options...
Duncan Posted February 22, 2016 Share Posted February 22, 2016 here's hoping someone else can help....I just use the consult and it comes with at least a basic description of the fault. Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7687223 Share on other sites More sharing options...
centoproject Posted February 26, 2016 Share Posted February 26, 2016 same boat as you pal no flashing just 4wd and abs light ? 1 Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7689530 Share on other sites More sharing options...
IBoughtANissan Posted February 28, 2016 Author Share Posted February 28, 2016 No luck so far mate. Got a mate with a consult connector so I'm going to chuck it on tomorrow and see if it comes back with anything. If you work it out please let me know mate Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7690125 Share on other sites More sharing options...
IBoughtANissan Posted March 3, 2016 Author Share Posted March 3, 2016 Cento, this looks promising; http://www.sau.com.au/forums/topic/190973-4wd-light-for-s2s/page-1 1 Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7692476 Share on other sites More sharing options...
centoproject Posted March 4, 2016 Share Posted March 4, 2016 looked into this beforehand pal unless yours is an s2 ? won't work i don't think the main problem for me is the fact i can't fine my diagnostics plug almost like it has been cut of Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7693008 Share on other sites More sharing options...
KiwiRS4T Posted March 5, 2016 Share Posted March 5, 2016 looked into this beforehand pal unless yours is an s2 ? won't work i don't think the main problem for me is the fact i can't fine my diagnostics plug almost like it has been cut of Just checking - it should be behind the coin tray but sometimes they seem to fall down or otherwise become detached. Have you had a look upwards from under the dash (need to be a bit of a contortionist)? Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7693060 Share on other sites More sharing options...
centoproject Posted March 6, 2016 Share Posted March 6, 2016 Just checking - it should be behind the coin tray but sometimes they seem to fall down or otherwise become detached. Have you had a look upwards from under the dash (need to be a bit of a contortionist)? i have looked right under the dash i can see the grey plastic bracket from its plug where it looked to have snapped off of its mount i may remover the lower dash section soon Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7693814 Share on other sites More sharing options...
IBoughtANissan Posted March 7, 2016 Author Share Posted March 7, 2016 For anyone finding this thread in the future. The above link I posted worked for me. (http://www.sau.com.au/forums/topic/190973-4wd-light-for-s2s/page-1) Link to comment https://www.sau.com.au/forums/topic/463070-how-to-retrieve-4wdattesa-fault-codes-s2-c34-stagea/#findComment-7694085 Share on other sites More sharing options...
