And, Course 6:
[media]
[\media]
You need to fab up a little clasp that goes over your harness clip and stops you un doing it mid slide :P
PS: I think I have your bad habit of leaving a hand down by the handbrake...
Thanks to all the execs and helpers that stood around in the rain so we could have fun! what a dedicated bunch of people. Sorry for the late sign on.
Had lots of fun, suffered for not being organised and sleeping in because the car was not empty and I now have very wet floor matts etc after leaving them in the rain.
  • Like 1
^^ THIS! So much THIS!
Chris, Dale, Nick and Ciaron you guys are Legends! Standing all day in the rain was a tough job and you guys were troopers! I know my back couldn't take standing all day, let alone sopping wet in the rain.
  • Like 2
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
