As title says 92 GTR done 117km
This car has been stored since 2006!! I just got it back from the shop yesterday after a full service and Blue Slip.
Has been painted at some stage in its life. Has aftermarket turbos, Power FC and full exhaust.
Neat and tidy car.
Perfect steering wheel!
Perfect dash
Almost perfect seats. One tiny mark.
Have been told it has a built bottom end but I have never pulled it appart to know.
20k
0400841142post-23484-14575051745919_thumb.jpgpost-23484-14575051887585_thumb.jpgpost-23484-14575052040656_thumb.jpgpost-23484-14575052178668_thumb.jpgpost-23484-14575052370492_thumb.jpgpost-23484-14575052516716_thumb.jpg
https://www.sau.com.au/forums/topic/463525-1992-r32-gtr/
The number of time wasters amazes me!!
CAR HAS BEEN PAINTED!!
Everything is there and is has good bones, all strong and runs well. Interior is perfect. The car is 20k !!!
Why do people expect a totally original glamour for this money? I sold my Glamour and got 37k in a day.
https://www.sau.com.au/forums/topic/463525-1992-r32-gtr/#findComment-7696745
We are the gumtree generation - everyone wants everything for nothing
There are some damn IDIOT buyers too. Trying to sell tyres and people offer me stupid amounts; respond by saying my minimum price so then they message me again a week later offering half of that. People trying shit on; dreamers!!'
  • Like 1
https://www.sau.com.au/forums/topic/463525-1992-r32-gtr/#findComment-7696906
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
